Question about Health & Beauty
Cant get the battery pack off 3 wheeled go go scooter. On the video it seems simply but mine wont budge
    Scholar:
  • 61 Answers
The battery pack on a Pride GoGo scooter simply lifts off but they can be very tight sometimes and require a good tug upwards. This should get a little easier with use though.
Hope this helps.
Posted on Jan 29, 2013
gewiz
  • 1271 Answers
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Posted on Oct 01, 2009
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
Posted on Nov 25, 2009
gewiz
  • 1271 Answers
SOURCE: my battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Posted on Dec 25, 2009
Testimonial: "Thank you for answering. "
  • 177 Answers
SOURCE: road knight mini, 3 wheel scooter, light flashes o...
Hi. Does the light flash a few times and then pause, and then repeat the flashing ? Count the flashes, it is a fault code. Do you have the fast/slow switch in slow? It might be a speed control fault. How old are the batteries? Might have a faulty motor. Faulty motor or battery leads and connectors. Go for a ride and then check if any of the plugs and sockets feel hot.
Posted on May 28, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
Want to see why my batteries wont charge. Product is new !
Is the charger getting power? Is the power reaching the battery pack to charge them? If you answer yes to both questions then something has to be wrong with the battery pack.
Jul 25, 2015 | Pride Mobility Victory 3 Wheel Electric...
My charger shows that my battery pack is charged but when I put it in the scooter it does not show it is charged and will not go
If the battery is old, it might be at the end of its useful life, You need to get a meter to check the voltage of the battery and the charger. Some chargers wont allow a battery to charge if it is totally drained. There is current sensing on those.
Jul 04, 2014 | ActiveCare Pilot 3 Wheel Standart Scooter...
Flat battery
the scooter will not move when plugged in, if you have a free wheel lever on the back to allow the scooter to be pushed make sure the lever is in the run position also have the batteries load tested
Mar 23, 2014 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
Scooter store wheel chair sat uncharged for a year. Now the battery wont recharge and operate.
Batteries left uncharged for that long will go bad and will need to be replaced. If you plan on not using the scooter for long periods try to plug it in once a week for 24 hours.
Aug 22, 2013 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
Can not get ear wheel off mobility scooter
rubbish answers. He cant get the wheel off and the answer is..take the wheel off?? Cobra do you know what a full stop is?
Jul 25, 2012 | Health & Beauty
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
Can you charge scooter without taking the batteries out? Is there an exterior spot to plug in?
You can charge the batteries with your offboard charger and the battery pack still on the scooter just plug the charger into the charger port on the side of the battery case and then plug it into the wall socket and charge overnite Will work just like if you removed the battery pack from the scooter. Hopw this helps you
Mar 26, 2011 | Pride Value Line Revo Scooter 3 Wheel
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
How do i remove battery on a go go scooter to replace it.
it should simply lift out and the whole unit is replaced by a new one. Hope this helps. Steve.
Dec 29, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Open throttle to full. clutch wont enegage for 3 to 4 seconds
Try a new belt, it may look fine but can be polished and have no grip left.
Jun 11, 2009 | RTO 50cc Moped Scooter
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
