My computer vga is no functionable - Computers & Internet
    Sergeant:
  • 369 Answers
Please check first the cable its fine or not if its ok then use the monitor with another computer to be sure its working if the monitor i s fine please open the cover of the computer and press the gfx card to sitfirmly in it slot also check the rams are sitting firmly in there position ...
BUT BE CAREFULL DO ALL OF THIS BY REMOVING THE POWER CORD AND WHILE YOUR COMPUTER IS IN SHUT DOWN MODE...
THANKS
Posted on Jan 24, 2009
How do I connect my Lenovo G500 to a projector and which keys do I need to press?
hi,
your computer looks like it has a vga out and a hdmi out, vga is less sharp but your projector most likely has this port. look at your projector and see if it has a hdmi port use that, if it doesent then use the vga, they sell both cords at any big box store,, the function keys(f1..) across the top of the keyboard are projector shortcuts...
https://forums.lenovo.com/t5/Lenovo-C-E-K-M-N-and-V-Series/List-of-FN-Function-Key-features/ta-p/700841
jm
Aug 01, 2017 | Lenovo Computers & Internet
Lap top does not function when I press the on button
Things to try or check. Remove battery pack and try turning it on with just the AC adapter supplying power. Try a different AC adapter. Try connecting a VGA monitor to the VGA port (on the side or back) of the laptop and press the Fn (function) key to enable/switch video to the external display.
Mar 15, 2014 | Dell Computers & Internet
I am trying to hook up a 26 inch viZio to my hip desktop utilizing the VGA cord. It won't come up? I am on the comp screen on the tv also.
Once you plug the VGA cable from the computer to the VGA port on the tv, get the remote for the TV and go to the Select Input function so that you can select PC or Computer as the input source. Then Reboot the Computer.
Once the computer reboots it will probably display on the tv. If not, Press and Hold the FN function key on the computer then hit the correct key (F1 thru F12) that toggles the display. The correct key (F1 thru F12) will have LCD/CRT on it or it might have the icon of a display.
Once it is pressed the video should toggle each time you hit it from showing on the Computer only, TV only, both the TV and Computer.
Apr 14, 2012 | HP Computers & Internet
Can't display with my laptop using VGA to 3RCA cable
Can't display where on another monitor or tv? Did you reboot the computer after plugging in the VGA Cable. Sometimes you have to hit the FN Function Key + F1 thru F12 to get the image to display. The correct F1 thru F12 key will have CRT/LCD on it or it might have the icon of a display. Press and hold the FN function key then hit the correct F1 thru F12 Key.
Mar 29, 2012 | HEWLETT-PACKARD ProBook Computers &...
A compaq sr1000 need to know what no VGA input means. Will no allow my computer to come on
Welcome to FixYa
No VGA input means that the computer is not detecting video input from the video card. Usually you get this message if the video card of your system is not functional, the VGA cable is unplugged or the VGA cable is defective. To try and remedy this problem try these.
Check if you can hear sound coming from the system. If the video card is functioning then you should here the startup audio from windows.
Check the VGA connection on the back of the system. The VGA cable looks like thismalups_6.jpg
Please note that the VGA cable has two screws, make sure that both are fastened correctly
If the VGA cable is plugged in and you cant hear audio coming from the system. Then this would likely be caused by a defective video card on your computer
Hope this helps
May 28, 2011 | Compaq Computers & Internet
No picture and when vga plugged into computer the screen keep blanking out
VGA is a high capacity video cable requirng for computers to have an enormous pixel density to capture to display beyond to another set devices. Usually with VGA cables, each devices computers, televsions, DVRs have to be high defination devices. Recent innovatons are all enabled to functions with VGA, only requires ascertaining the methods of connections. For example, VGA cables performs with capacities that disallows for the TV or computer to be connected to several devices that also request amount of extensvievss in pixel definitions.
Feb 14, 2011 | QPS Q-see QC444 Video Surveillance System...
Hocking up my computer to a t.v.
Hook The VGA Cord (PC INPUT) into Your Laptop's Hookup Spot
Turn The TV Input to VGA Or PC or Computer and on the Laptop it should show up if you Hit The Function Key + F8
If You Are using A Desktop Hook It To the VGA Out Just Like You Where Hooking Up To A Computer and Turn The INPUT on the TV to VGA or PC or Computer and it should show up just like A Computer Monitor
Hope I Helped
Dec 20, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Brand new Toshiba Satellite L305D-S5868 laptop display screen has gone black, even though the computer is on.
Since your laptop is brand new , you may not be familure with it's function keys , FN
Sometimes the users accidentaly presses the FN and the F5 monitor function key at the same time.
which effectively turns the notebooks display off.
D in the image below is the FN function key
and the monitor function key could be F5 , it will have a little monitor symbol on it.
When they are pressed together it will turn the notebooks display off and enable any VGA monitor connected to it's VGA ports. when pressed again , they will turn of the VGA port and turn on the notebooks display.
Thank you for using FixYa!
Az.
Sep 18, 2008 | Computers & Internet
Monitor fault
vertical controll is damaged
Aug 16, 2008 | SAMTRON 55V 15" CRT Monitor
Computer vga to tv
I'm guessing you've resolved this by now, but, if this is a laptop computer, it is actually a function of the computer that you are looking for and not the TV. Typically there is a key function assigned to directing the display to the laptop only, the tv only, or both simultaneously. On my current laptop it is fn+F8. On my old Dell I think it was ctrl+F8
Hope this helps, sorry so late.
Aug 06, 2008 | Panasonic PT-44LCX65 Television
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
