Question about Avaya Definity 302D Attendant Console 3274-11B, 3274-11G
302d console will not power up. Has 48v power supply to phone and has 48v at phone
Does OSN2500 have AC power supply?
No, OSN2500 power interface unit PIU is DC -48V input only, if you need a AC/DC power converter, please contact with Thunder-link.com sales team.
Feb 17, 2016 | Cell Phones
Slow printing
Either the power supply in not generating proper 48 Volts or the controller board is not detecting a 48V output from the power supply.
First of all make ensure that power supply and controller board are correctly connected (check for loose contacts). Unfortunately there's not much you can do. The problem is either in the power supply or the controller board. There is a special tool for testing the power supply and deciding whether to change the power supply or the controller. From what i've seen in the field, most of the times its the power supply that fails. I can send you the power supply test procedure. If youre interested letme know your email.
Jan 08, 2014 | Printronix P7000 FormLine PN P700502...
Nortel T7208 phone will not let me change password-locked
You can obtain the manual for this phone at the link below, which may help you reset the password.
http://phone.manualsonline.com/manuals/mfg/nortel_networks/nortel_business_series_terminal_t7208_nt8b26aabn.html
Cisco 48V Telephone Power Supply
Nov 13, 2012 | Nortel Business Series Terminal T7208 -...
Not working cisco 7962
For starters, have you obtained a Cisco Phone power supply for your 7962G? These phones require either a local 48V AC Adapter, or Power Over Ethernet, in order to power up.
Mar 04, 2011 | Cisco 7942G IP Phone
7945g can't use power supply of 7940
You'll need to buy a another power supply unless you have power over Ethernet. The power supply for 7940G/7960G is CP-PWR-CUBE and for 7941G/7945G you'll need a CP-PWR-CUBE-3. Yes, I know, I just got one of those and it's a pain to configure it, but I got it working... ;-)
P.S. If you haven't notice, you will be dealing with a whole different thing, the configuration/settings will ALL (except for the dialplan file) different from the 7940G... Good Luck ;-)
Aug 02, 2009 | Cisco 7945G IP Phone
I need a 5kW DC generator with -48v output.
I have 5kW generators that produce -48V DC. The problem is that unless your generator is designed to produce -48V DC it would be difficult to retrofit an existing AC voltage output with a DC output.
Nov 25, 2008 | Kipor Electrical Supplies
Connecting phantom microphones without result
if you have a volt meter check the supply is working correctly
48v dc phantom power should be found between these pins on any xlr mic cable.
pin 1 and pin 2
also between pin1 and pin 3
make sure you have amps turned down before checking/switching 48v phantom power
as if all is up and running it can cause big noise in the speakers.
let me know how it goes
Apr 29, 2008 | Sanken 48V Phantom Power Supply P11SPT...
Avaya Definity 302D Attendant Console 3274-11B, 3274-11G Logo
81 people viewed this question
Top Avaya Computers & Internet Experts
David Payne
David Payne
PhantomLib
Level 1 Expert
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
