Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Hp officejet 6500 paper feed roller comes down does not feed paper
Roller is running ...goes back up without feeding paper...says load plain white paper.
frcs68
  • 1605 Answers
SOURCE: Broken paper feed roller
you cn the roller from the link below:
http://www.precisionroller.com/manufacturers/hp-photosmart-c5280.html
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Posted on May 08, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
My hp officejet 6500 (E709N) will not feed paper from the feed tray. I just hear a stuttering sound. I can manually feed the paper, Is there a schematic or repair manual available?
No there is no specific repair manual for this, I have the same printer with the same problem. The problem is the pickup rollers responsible for the paper feed. And the printer does not dissemble easily without breaking something. I tried. you can send it to HP for repairs for a fee but they won't guarantee that they will able to fix it
Nov 03, 2016 | HP Office Equipment & Supplies
Hp Officejet 6500 won't feed paper
Problem:
The 'drop down paper grabber' gears are not turning, and the printer gives you an error saying to make sure there is paper in the printer.
All of the fixes on the internet are for working printers, and their approach is to clean the rollers if they are not grabbing the paper. They are assuming they are turning properly and the rubber grabbing wheels are wither dirty of dried out.
In my case, however, the gears were not turning, and so the rubber grabbers wheels were not turning, even though the whole 'paper grabber' unit was dropping down properly
Solution:
Just inside the paper loader tray, along the top, there is a metal rod. It is about 1 inch from the front.
The gears from the drop down paper grabber are supposed to meet a gear that resides on this rod and sort of floats on it. However, the gear on my printer slipped to the left, and was not making contact with the other gears.
You can gently put your finger on the gears as you do a copy command, and confirm this.
To fix the printer, I just slid the floating gear over to the right and into place, and the paper began feeding properly.
Why there is nothing to keep the gear in place is a mystery to me.
Aug 20, 2014 | HP Officejet 6500 Wireless All-in-One...
My 6500 OfficeJet has stopped feeding paper? How do I fix it?
Step one: Check the media and print settings
While the printer is on, remove the power cord from the back of the printer. Wait 30 seconds and then plug the power cord into the back of the printer.
If the printer is not already on, turn it on by pushing the power button.
Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.
NOTE: Use plain paper in the unit until the issue is resolved.
Make sure that the stack of paper to be loaded in the unit contains from 10 to 25 sheets of paper.
NOTE: Do not load too much paper in the printer.
Insert the stack of paper into the printer and gently push the paper guides snugly against the paper.
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
Open a document in the program in which it was created.
Click File .
Click Print .
Click Properties . The Printer Properties dialog box displays.
In the Size is drop-down menu, select the size of the paper loaded in the unit.
In the Type is drop-down menu, select the type of paper loaded in the unit.
Click OK .
NOTE: These changes do not change the default print settings. The print settings will revert to the default print settings the next time the program is opened.
On the Print dialog box, click OK to print the document.
Try printing again. If the issue is not solved, continue on to the next section.
NOTE: If the issue is resolved and you want to print on another type of paper, change the paper in the unit and then repeat steps 2 through 7 for the new paper.
Step two: If necessary, obtain the HP Paper Feed Cleaning Kit
Some inkjet products require a special kit to resolve this issue.
Determine if the serial number is in the appropriate range
Locate the serial number on your product.
If the third and fourth digit of the serial number is 56, 57, 58, 59, 5A, 5B, 5C, or 61 , then use one of the Contact HP links on this page to contact a support representative. If your product is still under warranty, tell the representative that you need a free HP Paper Feed Cleaning Kit (part number c9000-67901). If your product is no longer under warranty, you can purchase this kit online from HP. Click here for region/country ordering information.
If the third and fourth digits of the serial number are not listed above, you do not need the special cleaning kit. Continue on to the next section.
NOTE: A USB connection is required for your Windows 98SE, Me, 2000, or XP computer to use the HP Paper Feed Cleaning Kit. If the product is not already connected by USB, connect it through USB before using the patch, or the kit will not work.
Step three: Clean the rollers
Turn off the unit and unplug the power cord.
Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. Refer to the product User' Guide for information on locating the rollers.
Clean the rubber rollers with a lint-free cloth lightly moistened with water.
NOTE: Purified or distilled water is recommended for cleaning the rollers.
Close the access door and plug the power cord in.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Cause
This issue might be caused by any of the following:
The paper tray is not completely inserted into the unit.
The paper settings in the printer driver do not match the paper loaded in the paper tray.
The rear rubber paper feed rollers are coated with dust.
Jan 11, 2011 | HP Officejet 6500 Wireless All-in-One...
HP officejet wireless 6500 printer won't print
Oct 03, 2009 | HP Officejet 6500 Wireless All-in-One...
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 6310 - paper misfeeds and bunches up to one side when feeding into printer, causing paperjam. I tried cleaning the rollers, with poor results. Thanks for any help.
Please try these steps
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 7310 allinone
Jan 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam message but no paper is jammed. how do i fix it (hp officejet 55210 all-in-one)
Jan 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Howto dismantle officejet printer 5610, and remove battery
well if you are having a paper feed problem then you dont need to disassemble the printer. observe the area where you feed the paper in and you will see two rollers pressing don on th paper when loaded. theas two are spring loaded to adjust to the thickness of the paper in the tray. 10 sheets or tyenty five . it still appplies downward pressure on the whole stack of paper. The rubber roller is on the right ,and a hard plastic one on the left. the rubber roller is the motorized feed roller. Clean both with a q-tip.
Nov 30, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Seeker5211
Seeker5211
