Question about Fellowes PS70-2CD Shredder
Fellowes ps70-3cd shredder green red light - Fellowes PS70-2CD Shredder
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
fellowesrep
  • 102 Answers
SOURCE: Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
fellowesrep
  • 102 Answers
SOURCE: shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Posted on Feb 26, 2008
fellowesrep
  • 102 Answers
SOURCE: red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
SOURCE: Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Posted on Mar 05, 2009
Red and green light is on but it wont shred
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Nov 13, 2012 | Fellowes Powershred PS-60 Shredder
Wiring diagram for a Fellowes PS 60CC shredder
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
Jun 29, 2012 | Fellowes Powershred PS-60 Shredder
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
Red light on as well as green,what is the red light
The red LED can mean one of two things -- either the shredder head is not assembled correctly (did you take the shredder apart recently?) or there is a paper jam inside the machine. Sometimes the jammed paper is far down and hard to see.
Jan 30, 2010 | Fellowes PS60-2 Shredder
Green and middle red light go on but motor does not. does not shred
Check the sensors on top and bottom of cutters. Clean with cotton swabs and compressed air. If this does not help, bad sensors or main board.
May 14, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
Red light on with green light
Oct 16, 2007 | Fellowes PS70-2CD Shredder
Fellowes PS70-2CD Shredder Logo
62 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
