B&Q airforce electric oil heater stopped working
Power fine but heater will not turn on. Lights OK - so it is getting power. Has worked fine for five years or so. Stopped last week.
Kimi
  • 277 Answers
SOURCE: Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Posted on Dec 04, 2005
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
Dr Fly
SOURCE: honeywell ceramic heater hz341bl
Like most heaters, this Honeywell ceramic heater has a tip switch designed to turn the heater off if it falls over. Unfortunately, all you need to do is bump the heater and the switch can open. Sometimes the switch will stick and the heater won't come on even when it is upright—sticking during storage could easily happen, particularly if not stored upright. When the switch is stuck on my heater, when I try to tturn it on the yellow and green pilot lamps flash once but nothing happens.
The solution is to rattle it, shake it, and invert it a few times to unsitck the switch. It always works for me. Something probably best done before you get frustrated to the point of shoving it through the floor. Also, if the heater was running when the switch sticks, be sure it cools down so the thermal switch has a chance to come back on.
Posted on Aug 26, 2008
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
PrettyEasyGo
SOURCE: No electric power when plugged in and turn on switch/cuisinart DC
tried ALL solutions on this & other blogs-even to point of CAREFULLY drilling out plastic to get bit-holder down to the 'MAGIC FASTENER' level and then trying: #10 TORX; ## 7-10 TORX; 'security TORX(with hole in middle) & several other 'secret bits'---ALL TO NO AVAIL !!!!! :0(
then, in SHEER DESPERATION, called Cuisinart @ 800-726-0190 [this is on SAT morning 0915 on 3/28/09] got VERY HELPFUL/KIND/PATIENT rep who was ready to do the " $10 +old one AND $10 for new one" routine, when she said: "Did you try re-plugging into wall socket after 1 hour? That's the re-set time" !!! while she was on the line (they work 'til 1730 EDT on SAT/SUN & 'til 1100 M-F !!!) wife tried this highly-technical/super-secret solution -and- IT #$%^*'ING WORKED !!!!!! ;0) I'm sitting here drinking coffee outta it and posting this solution.
Posted on Mar 28, 2009
My wipers...lights..radio and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
www.carcomplaints.com/Chrysler/Town_Country/.../intermittent_electric...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix
www.topix.com > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
forum.chryslerminivan.net/.../7261-I-lost-almost-all-of-my-dash-lights-i...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
Dec 16, 2015 | 2004 Chrysler Town and Country
The starter on my 1995 saturn sl2 stopped working i can still push start the car but in the same day the heater fan and cooling fan stops working but then starts working again when the fans don't work the...
You have a electrical power shortage, when componets demand power it's not there [ that's why some componets slow or stop working ]. Start by cleaning the battery terminals and testing the battery to see if it holds a proper charge [ after fully charging, let the battery sit for a few hours and check the voltage = it should be at least 12 volts. If not, replace. Then check the output of the charging system = mininum of 13.8 volts to maxinum of 15.3 volts, & up to 78 ampress when @ maxinum charing. Then check the starter draw = should be around 260 amps, if it's higher then 300 amps. then replace.
Feb 21, 2011 | Saturn SL2 Cars & Trucks
Hi I have a hobart airforce 250ci 2 and a half year old lightly used plasma and the power doesn't come on
Check your ground and make sure the ground is clean, if not sand it slightly where it's shinny then try tighten the ground clamp and tighten the ground clamp on the machine itself. Be sure the breaker is not tripped for the machine in the main electrical panel as well check that the electrical cord has not worn down from use, you may have to replace the electrical connector if it is badly worn. you can buy at any hardware store, you will want to buy a 15 amp male connector. If this does not sole your problem please let me now for more help. also be sure air is working for the machine.
Aug 07, 2010 | Hobart Airforce 250ci Plasma Cutter 12...
POWER UNIT IS NOT WORKING
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Left Heater switched on over night, oil radiator de longhi dragon
1st, check the electrical cord plug; because of the hielectric demand, thesaes plugs overheat and form a burn coating on the prongs that stops the hilevel of electric but allows a small level ofalaectric that still lights the lights but no power for heat.
2nd, the thermostat is not making contact: it is a bi-metal contactor that sometimes burns or loses its strength and no matter where you turn it it wont work. You can simply cross the terminals of the thermostat to see if you get electric flowing (you have to open the oen housing to do this.
3rd, the element could be burned-out or (as often happens) the connection to the heat element burns-off. Again, you need to open the end housing and look, or take it to a small appliance repair place.
Oct 11, 2009 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
I actually have three issues electrically with my 2005 Envoy XUV. The most important one is the running lights. First the running light feed to the trailer connection ( factory installed ) fed no power to...
1) Look for fuse 32 in underhood fuse panel, I believe this is for trailer lights. 50 & 51 are for R and L trailer brake.
2) The blower resistor pack is defective, this is located behind the glovebox and mounted to the blower body.
3) I have no solution for tailgate problem, suggest visiting Trailvoy.com forum and doing search on XUV tailgate.
Sep 14, 2009 | 2005 GMC Envoy
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
