Question about Maytag Dryers
Drum will not turn
Hyg3460aww
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Belt may have broken if you still hear the motor running
Posted on Jan 16, 2013
MAYTAG DRYER MOD.HYG3460AWW . THERMAL FUSE BLEW. REPLACED IT. IT BLEW AGAIN, WHATS THE PROBLEM.
The most piticial problem whena thermal fuse continually goes out is a blocked of restricted vent
Jul 26, 2011 | Maytag Dryers
The gas wont light
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag HYG3460AWW Gas Dryer
My gas dryer isn't heating at all. The model # is HYG3460AWW. Do you think is't a thermal fuse?? and do you know where it's located??
Possible cause is a bad ignitor. Alot of gas dryers have a ceramic hot surface ignitor. If you can access it, Look and check for cracks. Do not touch the ceramic portion. Oils from your skin will cause a failure if that is not the cause. Other failures can include limit switches and thermostat. In my expierece the hot surface ignitor is the most common failure.
May 01, 2010 | Maytag HYG3460AWW Gas Dryer
Drum will not turn dryer gets hot
If you hear the motor running; then most likely the belt has broken.
Dryer runs and blows cold air but no heat
If your dryer2_bing.gif is electric..
heatman101
Apr 26, 2010 | Maytag HYG3460AWW Gas Dryer
Dryer stopped spinning
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jan 23, 2010 | Maytag HYG3460AWW Gas Dryer
Dryer spins but doesn't heat
most probably you have a blown element if it is an electric one also your thermostat could be faulty look also for burnt or loose wiring hope this helps
Nov 14, 2009 | Maytag HYG3460AWW Gas Dryer
Works but doesnt spin. Where is the belt located. I think that might be the problem.
To access your drive belt, you need to take the front cover off. Unplug the dryer first.
There should be 2 screws on the front cover in the lower front area. Remove the screws and tip the bottom of the front panel forward until the top clips are frree of the top panel. Be careful there is a door safety switch wired. You can disconnect the wire and set the front panel aside.
Look under the drum in the dryer and you'll be able to tell if the belt is broken or loose.
IF you need to replace it, you'll need to take the 4 screws that hold the front drum support/duct assembly loose from the dryer case. Once these are removed you can pull out the whole gray assembly and slide the drum out.
The new belt can be purchased online at repairclinic.com if you want.
To put back in, you can put the belt around the drum and slide it back in. It should have a grooved side and a flat side on the belt. Put the flat side toward the drum. It routes around the motor pulley and a tensioner pulley. It may take a bit to figure out the routing, but the key is to put the belt into the indentation ring on the drum to allow you to get it around the pulley and tensioner... if you leave the drum sticking out of the machine about 8 inches, you can reach thru the drum and hook the belt in place, then slide the drum in and pull the belt out of the indentation and onto the larger circumference of the drum. You may have to twist the belt to get the flat side next to the drum.
You can then put it all back together...
Good luck... be patient and you can do it.
Sep 10, 2009 | Maytag HYG3460AWW Gas Dryer
Black Film on the inside of the dryer drum. Transfers to clothes.
The gas is not mixing properly with the air. You could have a blocked or restricted vent which has caused lint to back up in the machine thus giving you a poor burn. Check your venting and if it is clogged you may need to dismantle the dryer to clean it out inside. :)
Apr 09, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
