Question about Craftsman 315.174710 Routers
Locking mechanism stuck
Frozen open and will not lock
Driver door lock won't respond to remote, but key in lock won't turn either. Would both be fixed with a new actuator?
More likely, there something frozen or broken in the mechanism you can fix. If the lock mechanism is frozen, a new actuator won't fix anything.
Nov 06, 2015 | Honda 2003 Pilot EX-L
Liftgate won't open
They have a history of this problem. Likely something is stuck in the lock mechanism.... dealers can pop this open for you. It happened to my Explorer once. Couldn't get her open, found a piece of towel stuck in mechanism of liftgate lock
Mar 30, 2014 | 2006 Ford Explorer
Car door frozen shut
LOL. I hope you mean stuck and not truly frozen as I would recommend hot water if you really meant such.
If stuck, this generally happens when the doors are not used often as the seals will stick to the door and body. You can use WD40 around the door and it will work its way in between and allow you to open it. Once open, you can use a dry lubricant to prevent it from happening, wax will work as well.
This is providing it is the seal and not a faulty door lock mechanism. If it is this, then you will need to use a slim jim to open the door so that you can remove the interior panel and replace the part.
Jan 06, 2014 | 1997 Lincoln Continental
Car door lock stuck on 1990 Ford Crown Victoria
This car came standard with power door locks and the lock actuators are frozen up and this keeps you from turning the key to open the doors.
Sep 17, 2012 | 1990 Ford LTD Crown Victoria
I can't get the door open on our washing machine, a SIWAMAT XLS 1650. Is the locking mechanism electronic, or mechanical?
The locking mechanism is electromechanical. If the machine is switched on for its cycle & then off, it takes about 2 minutes to open. In normal course it should open it immediately. Your locking mechanism is stuck & needs to be replaced.
Sep 18, 2011 | Siemens Washing Machines
The lock on the oven door is stuck on lock and the oven door is open.
OK, this is oven door lock mechanism failuer. check the connections that lead form the door lock mechanism to the control board. if the wiring harness is in good condition and, the connectors are not corroded, simply replace the door lock mechanism(assembly).
Jun 09, 2009 | Ovens
1995 M series has auto door locks at ignition. passenger side has frozen. Will not open even trying to use key.
The door catch/lock mechanism on the MX5 is liable to do this occasionally - if you keep trying to unlock it, it will open eventually (I manually pop the internal lock whilst opening the outer handle if that makes sense).
Once it's open though, you pretty much need to open up that door and replace the lock mechanism.
Hope this helps,
Sherwin
May 14, 2009 | 1995 Mazda MX-5
My 2001 Chrysler Town & Country passenger sliding door won't open
your door panel can come off and you can access internal door locking mechanism from inside car first inspect to see all rods are hooked into plastic sleeves then make sure lock is disengaged by pulling rod towards rear of van it should then be able to be opened easily if not your locking mechanism is frozen inside of door between a pillar and door it will have to be pushed to open from inside of door panel once you do that door will open if you cant make lock work manually once this is done replace locking mechanism or rods accordingly.
Feb 02, 2009 | 2002 Chrysler Town & Country
Door lock stuck
If the mechanism is jammed, you might have to remove or loosen the entire front panel to reach back to the back side of the lock and work on it.
Feb 25, 2007 | Whirlpool GHW9400 Front Load Washer
Craftsman 315.174710 Routers Logo
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
