Question about Panasonic MC-V7600 Bagless Upright Cyclonic Vacuum
Panasonic Stow'n'Go, model MC-V5481
This vacuum does not pick up well at all. And now when I start it up there is an opening on the back with a seal or something that breaks loose amking a loud hissing (airleak) type noise while running the vacuum. When I shut it off the hole seals once again and the vacuum sounds normal for just that moment. If you use the hose only there is major suction. Why doesn't the rest of the vacuum work like this or does it have something to do with the hole that seems to promote a leaking sound. This vacuum is realatively new, well taken care of and is destined to be the last Panasonic I purchase if I can't get these problewms solved. Thanks so much.
Thank you so much. It was clogged in that area.
Posted on Jul 16, 2007
If you turn the vacuum over, you will see a hose by the brushroll. I think your problem is that it's stopped up right there. Take off the brushroll and make sure that the hose isn't stopped up. The port at the back that makes a hissing sound is to indicate that it's stopped up somewhere. Also, when you replace your attachment hose back onto the machine, does the motor change sound?? That's also another indication that your machine is stopped up. Don't lose hope for the Panasonic, they're great machines. If you still need help, you may call us at 1-866-509-1952. Thanks.
SOURCE:
DC25 vacuum not picking up just moving dirt around. Hose stretched to max to get suction. What could problem be?
Check filter on canister. It's on top. Might be full. Also make sure the one for the hose door at the back, sometimes it breaks so it will be open. You can manually close it if it's broken.
http://www.vacuum-manual.com/manuals/dyson/Dyson_DC25.pdf
Jun 10, 2017 | Vacuums
SE rainbow vacuum break down photos
You are supposed to put water in those vacuums there should be a video on YouTube my mom had one like back in the 80s hope this helps Merry Christmas
Dec 09, 2017 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
Need part number for hose alone for panasonic MCV9610
The following hose fits models MC-V9610, MC-V9620, MC-V9635, MC-V9647.
It can be found at: http://www.pasc.panasonic.com/epartr/PartsListChoice.asp?validate=1
AMC94P-GEZV004
Jan 08, 2011 | Panasonic Vacuums
Belt is melting or burning not sure why
It doesn't matter what or why. Use your owners manual and it will show you how to change the belt. When you open it up whatever is hanging the brush roller up will either show itself or when you remove the brush roller it will fall out. Change the belt. That smell is the motor shaft slipping past the belt and burning it with friction. Either way the belt will need changing if it's had that much wear on it.
Mar 07, 2010 | Panasonic MC-V5481 Upright Vacuum
Need owner's manual for Panasonic MC-9420 canister vacuum cleaner
goto> http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Vacuum-Cleaners/Canister-Vacuums/model.MC-3920
Feb 21, 2010 | Panasonic Vacuums
Panasonic MC-V7600 Bagless Upright Cyclonic Vacuum Logo
151 people viewed this question
Top Panasonic Vacuums Experts
Archie Ferrarini
Archie Ferrarini
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
