Question about RCA L32WD250 32 in. LCD HDTV
Picture will not come on,the screen has a light blue faint color and sound,no picture sometime has red lines
    Top Expert:
  • RCA Master
  • 45,144 Answers
Power supply failure
Posted on Jan 16, 2013
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Projection lights don't line up
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture and sound problem at 21" sony waga color tv
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
Feb 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Multiple problems, hoping for one solution
sounds like it is probably worth trying to degauss check this excellent site; http://woil.ws/fixmonitor/ for details of how to try this on the cheap - it works If it doesnt solve your problem, the fact that you are getting different quality from different crt s suggests that they could be the root cause - see if you can get the part number, and get a price you may find it is cheap enough to be worth trying - check also the power supply - poor voltage output can sometimes cause these type of symptoms. Hope this helps, if not post again - some of the other guys know tvs much better than me :)
Mar 08, 2007 | Sony KP-53S65 53" Rear Projection...
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
RCA L32WD250 32 in. LCD HDTV Logo
105 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
