Question about Sewing Machines
White rotary sewing machine model 77 mg take up and needle not moving how do I fix it?
I'm looking at a 1950's white rotary for purchase. the motor is working and the disk wheel turns, but the needle is not moving up and down. Am I missing a setting on the machine? How do I troubleshoot the machine.
bibleman01
  • 334 Answers
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
louislevel_2
  • 374 Answers
SOURCE: needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Posted on Mar 15, 2009
bargainbox
  • 1388 Answers
SOURCE: I have a brother XR-37. I was in the middle of
Did you find the broken bit of the needle ?
It may be jamming the bobbin case area and hook. Remove the needleplate and bobbin case and clean it all out then report back with progress.
Posted on Sep 02, 2009
  • 3741 Answers
SOURCE: Kenmore 158.1703 sewing machine - needle not going up and down
The machine sounds like it has threads caught in the bobbin area thus locking the machine up. Check in there and maybe you can pick them out with tweezers. They may need to be 'softened up' with a little oil before you can get them out!. also Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew.
------This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 05, 2010
1950 Featherweight sewing machine
Look at manual for threading. That shouldnt cause clicking. Is needle new? in correctly? Bobbin also? Can you see what is bumping? Then, Take it back. Maybe they inadvertently moved or loosened something.
Jun 03, 2013 | Sewing Machines
Needle won't move.....
I cannot find anything about "American Standard Sewing Machines" in a google search. Thoughts: sounds like your gears are frozen. I would take it to a different repair shop. Try to find an older person to repair it. Never under estimate the old guys.
Aug 22, 2012 | Sewing Machines
Have a White Rotary Sewing Machine Serial number FR2701777. What model is it?
check with these sites about a manual & needles,,you'll need
to email them the name & serial number & ask them, they should
be able to help you
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
Aug 03, 2012 | White Sewing Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Hand wheel & needle do not move
it's possible that something has come loose or broken on the inside of the machine.
the name & model number of the machine is not shown, if the machine is mechanical it probably has a handwheel clutch,, make sure the smaller inner knob is tight. then try to sew again
if you still can't sew then I suggest you have the machine checked, because it's not reponding like it should
Apr 01, 2012 | Sewing Machines
Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Mar 18, 2012 | White Sewing Sewing Machines
Singer Athena 2009 needle hitting plastic in bobbin case
here's something to check
is the needle inserted all the way in to the needle holder?
needle--flat side goes to the back of the machine
is the needle clamp screw tight or loose?
if the needle is correctly in the needle holder & the needle clamp screw is tight --then the needle bar is out of time & need to be serviced
IF YOU DO HAVE TO TAKE IT TO BE SERVICED AFTER YOU GET IT HOME STOP RIGHT THEN & SEW ON THE MACHINE TO MAKE SURE THEY FIXED THE MACHINE & IT SEWS LIKE IT SUPPOSE TO, I HAD ONE CUSTOMER THAT TOOK THEIR MACHINE TO A SHOP & THEY CLEANED IT AGAIN & DIDN'T FIX IT BUT CHARGED THEM FOR IT & THEY BROUGHT IT TO ME TO FIX & IT HAD TO BE RETIME
did you get a instruction manual for the machine if not check at singer
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number---2009
Click search--if you don't see a manual--contact singer customer service
Feb 11, 2012 | Singer Sewing Machines
My white rotary model 2221 sewing machine will no longer switch from straight to decorative or zigzag stitching. What can I do to fix it? I have cleaned and oiled the machine and have recently used it...
it's possible that the cams that do the zigzag stitch could be worn or have gotten damaged
it would be a good idea to have it serviced
I would suggest to look in the yellow pages & see what sewing machine repair shop are in your area.
and if you do get it serviced, when you first get it home, sew on it & make sure it works correctly, they normally have a 15 to 30 day time limit for you to check the machine out & making sure it works ok, & make sure that you don't just pay for a cleaning..
Sep 11, 2011 | White Sewing Sewing Machines
Sewing Machines Logo
138 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
