Question about ViewSonic VG150 15" LCD Monitor
Viewsonic VA1912wb is only displaying black and blue
When I am in the monitor settings with manual buttons on the monitor, I am seeing full range of color.
Is it my video card. I have an HP Windows XP... don't know what video card it has, probably what came with the machine.
thanks
  • ealmekinder Jan 24, 2009
    Thanks for suggesting I start my system in safe mode. My View Sonic is seeing all of it's colors... hurray!
  • Jay
    Jay May 11, 2010
    What kind of monitor do you have is it new? Was it tested before you bought it? If it was you could either have a failing Video card or monitor.
    Try reinstalling the Video Card driver see if that fixes the problem.
    Guru:
  • 170 Answers
To be sure the system is actually on press the caps lock key when on if it comes on then yr problem should be from screen display.what to do.
*disasemble the screen area then check the module,conector then the screen itself to know the actual problem. most times when u lose and tight back u find the problem solved so try it out.
if u don't get solution then call on my cell no.+919779366100.
Thanks alot,
Sanjeev Kumar
Posted on Jan 24, 2009
What is the default display settings for VA1912w
Viewsonic VA1912w
Optimum Resolution 1440 x 900
VGA up to 1440 x 900 non-interlaced (max. 60Hz)
May 26, 2014 | ViewSonic VA1912wb Monitor
Sir i am having viewsonic va1912wb black monitor , that was not getting display so please can u give me troubleshoot sir
hi dear friends step 1:check all the monitor wire step 2:if wire is correct then u must take a computer shopkeeper to clear a right solution
OK i hope you are agree with me thanks!
Apr 07, 2011 | ViewSonic VA1912wb Monitor
Received "out of range" error
Your video card may not not support the current setting of your desktop resolution.
Right Click on your desktop. Select Properties. Appearance Settings. Adjust your display lower like 800x600 or 1200x900.
Mar 20, 2011 | ViewSonic VA1912wb Monitor
I pushed the button next to the power button now i have no screen, i pu7shed the button again but to no avail, please help
Common failure is the caps in the inverter/power board, look for caps with bulging tops, see example of failed VIEWSONIC monitor due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA1912wb Monitor
I have a VA1912wb ViewSonic monitor. Lately, when I power on the computer, the monitor is black, I press the buttons on the monitor, it takes 5-10min to power up.
The viewsonic monitor is a good unit.
If the unit takes more than 30 seconds to power up, you have a problem with the power supply and will have to be repaired.
Oct 20, 2009 | ViewSonic Computers & Internet
No display on Viewsonic VA1912wb
Your monitor sounds like it has gone bad. Cost for a repair is not worth it, a new one would be cheaper. Prices have gone down a lot in three years
Sep 11, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Can't see full desktop
Change your screen resolution in System Preferences >> Displays. Experiment until you find what is the correct setting.
Aug 01, 2009 | ViewSonic VA1912wb 19" LCD Monitor
The screen is black even though the green light is on
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VG150 15" LCD Monitor Logo
99 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
