Question about HP LaserJet 2605dn Printer
Hp 1525 printing blurry images shadow - HP LaserJet 2605dn Printer
5 Suggested Answers
SOURCE: HP Color LaserJet 2600n imaging problems
try the clean heads and alignment in the print manager..
Posted on Aug 20, 2008
iron_luiggi
  • 91 Answers
SOURCE: I have an HP LaserJet 3600n. My color prints with
When printing starts dating hp defective in 3600, the first thing we do is check the cartridge, there are people who change the cartridge with a new, and it should work. But there are cases in which the impression is going wrong, something like with shadows, colors out of phase, defective printing colors, mostly magenta and cyan are those who are affected.
To ensure and achieve better results, we must make a full calibration on the printer, we are guided by the menu on the printer control panel.
If it still does not work, there is a bit complicated procedures pertaining to resolved the problem.The question is to clean the mirrors and lenses of the laser unit of the printer. this unit is one of the last pieces that fall apart, we must be careful to start.
WHAT WE NEED?
SERVICE MANUAL: http://cid-4c0169bf00ee97eb.skydrive.live.com/self.aspx/Manual% 20of% 20HP% 20Servicios% 203600n/HP% 20Laserjet% 203000-3600-3800-CP3505.pdf
PHILLIPS, DE STRIA
SCREWDRIVER FLAT PALLET
IsOpen (Q-TIPS)
1) We must have your service manual for the printer, there tell us where and how to disassemble some parts to get to the laser. Preferably we should have it printed, but obviously not all of the manual, only the pages you need.
FROM 82 TO 93 (here shown as removing the outer parts of the printer front cover, back cover caps
eye: what part of atraz removed, we must remove the card from the left side (from the back, not side) simply pull the black hooks that are located on the side of the entrance to the usb and network and pull the whole card.
FROM THE 128 TO LA131 (LASSER / SCANNER ASSEMBLY - Here we indicate how to remove the top metal cap, the connecting cables to the card, where you must take special care, the 10 metal screws on the back cover, the harness holding cables, and finally after removing the ventilation channel, we find black laser module, remove the five screws there and we set the laser in your hand (you need to move to the left and then remove it)
Until then helps us service manual Hp. and after that we must uncover the laser unit, has a single black screw in the middle, we take away and sides is about 4 hook bras, we carefully removed, open the laser unit, and clean four ultraviolet mirrors with a QTIP, swab, SECO, it is important that we do not clean the monks also mica, transparent lenses, and all but the 2 motors round. Carefully clean and again, the amount of dust does not show significantly, but does significant damage to the image to the printer.
To which we clean, we set the laser housing once, store it in a bag to protect you from falling back blow dust as the printer and proceed to clean the printer with a blower or vacuum, with emphasis on the fans. After this is done, we took the unit from the bag and started to ride all over again in reverse order.
We should be particularly careful when reconnecting all cables should fit snugly.
Reassemble everything, turn the printer, perform a complete calibration or two colors meet again alive, sharp and deep.
WHAT could go wrong?
When you turn on the printer, you can give an error message if this happens we MUST check that error number is here:
http://www.printertechs.com/tech/error-codes/error-codes-index.php
leave something here and I doubt I will do my best to answer
Posted on Apr 13, 2010
  • 385 Answers
SOURCE: My HP Deskjet F 4480
sounds like the alignment is off. try alignment adjustment from the utilities options
Posted on Sep 07, 2010
Testimonial: "Thanks!"
donald2124
  • 11 Answers
SOURCE: How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Posted on Jan 01, 2013
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
Almost every caracter I try to print comes out with a shadow and blurry with my HP Deskjet F4480 printer. Can you help? Does it have anything to do with the ailgnment page used in the installation...
You may have to do another alignment of the printer.
Do a Clean the Print Cartridge cycle first.
This will allow the printer to print a good alignment page.
Mar 01, 2011 | HP F4480 All-In-One Printer
Whenever i print a test page everything has a shadow behind it, making it look blurry.
Dear Sir,
If your using new catridge please goto Printer service option and clean the head once. Then youwill get clean print.
Thanks
Sep 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
PRINT IS BLURRY
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
HP laserjet 2600N shadow printing
Check this link from HP. The repetitive image "ruler" identifies the source of the repeating image.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826
Sep 29, 2008 | HP Color LaserJet 2600n Printer
Aug 20, 2008 | HP Color LaserJet 2600n Printer
59 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
