Question about HP Compaq Presario C304NR Notebook
Keyboard beeps but no movement - HP Compaq Presario C304NR Notebook
  • HP Master
  • 27,725 Answers
Laptop keyboards are a little more delicate than keyboards used in desktop computers. Hence they face more problems. Normally, they are replaced when they render defective. However, most of these keyboard issues can be taken care of or even prevented by regular cleaning. Common issues like, keys not working on your keyboard, having to press keys firmly to get the output or any keyboard typing issues, can easily be handled at home.
Sometimes you may find certain keys of your laptop's keyboard to not be working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are supposed to maintain your laptop's keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. To start with, take out each key. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry. Once you have cleaned and lubricated all the parts, carefully reassemble the keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it. The complete process will take you a maximum of 2 hours. Cleaning and lubricating the keyboard in the above prescribed manner once a year, can prevent many such situations. Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem.
This was all about solving your laptop keyboard problems that you can try out yourself. After trying all the above given options, if you still find the keyboard still not working, you will have to take your laptop to a service center to get it repaired
Hope this helps.
Posted on Jan 16, 2013
Random continuous beeping from Acer Aspire and i bought it in September so it is a brand new computer and it does this either way is plugged in or not and it happens randomly
Mine beeps if the charger isn't plugged in completely or connecting completely. It does it persistently if not connected completely and I tap the keyboard (slightest movement) good luck.
Nov 29, 2012 | Acer Aspire 5100 Notebook
Milwaukee M18 recipricating saw beeps, won't run
you possibly have a bearing/gear problem restricting movement of the mechanical parts. I would try and remove the gearcase first and just try the motor section before going any further. This will narrow it down.
Jan 15, 2012 | Milwaukee Saws
Have a Intell D865PERL getting either 6 or 7 beeps when booting, can't be sure which. System will not boot but just beep with PS2 keyboard installed but will boot with keyboard removed. BIOS is version...
It's likely a bad keyboard- try using either an usb keyboard or another ps2 keyboard- if it works and boots normally with a different keyboard, the issue was the bad keyboard. If not, then the ps2 port has gone bad. (you could still use usb)
Feb 01, 2011 | Intel D865PERL Motherboard
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Stop beeping please! Tick off mode
Page 7 of the instruction manual.
Press menu once.
3 icons will flash - tick, sound and movement.
Press the UP arrow, two or three times until the combination of functions you want are showing (in this case, sound and movement, but no tick). Press SELECT. Job done.
Jan 27, 2010 | Angelcare Deluxe Movement Sensor & Sound...
Our son was trying to log into a game and the keyboard froze. It just beeps when you hit letters or other keys. We don't know what he hit! We've had the keyboard for several years, it is wireless, no...
Does the keyboard beep, or does the computer beep?
Move the keyboard into a different room, so that you can determine the source of the beep.
Remove the battery from the keyboard.
Insert a fresh battery.
Dec 27, 2009 | Microsoft Computers & Internet
Personal Wheelwriter 2 Problem
Look for any debris under the carrier that will interfere with the movement, then put some WD40 on the silver shaft that the carrier slides on.
DickyO
Dec 26, 2009 | IBM Wheelwriter 30 Typewriter
Mouse has a mind of its own. The Logitech Wireless MX 3200 keyboard is fine. But, the wireless mouse movement and cursor movement on screen do not sinc with each other. I cannot do precise movements and...
I know this might sound too simple, but I ahve found that if I do not make sure I am moving my wireless vertical and horizontal, but diagonally...It goes haywire...
Also; You might be able to adjust the sensitivity in your control panel
Aug 22, 2009 | Logitech Cordless Desktop MX3200 Laser...
3 long beeps (keyboard?) and no video. Tried a second keyboard, same result. Keyboards work with other machine.
This information will help you out on the POS beep codes.
http://www.computerhope.com/beep.htm
i suspect that its not on the keyboard but if you have keyboard card, thats the problem . Try to check your motherboard if it beeps without any memory.
If it beeps then probably your motherboard is ok. Try to change your video card if you have an extra, but dont buy yet, unless you already proved that your video card works.
Aug 18, 2009 | Gateway 507GR PC Desktop
IBM wheelwriter 15 Series II not working
It sounds like the keyboard is bad. Check the two bflat connectors from the keyboard to the PC board, if they are connected ok a keyboard is in order.
DickyO
D
Dec 30, 2008 | Lexmark Wheelwriter 15 Series II...
HP Compaq Presario C304NR Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
