Question about Microwave Ovens
GE Profile JVM1870CF001 EXTERIOR NIGHT LIGHT BULBS
Located underneath microwave. 2 bulbs
MicrowaveSvc
  • 9085 Answers
SOURCE: GE XL1800 Microwave Night Light Inoperative
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 03, 2008
SOURCE: GE spacemaker xl 1400, lights on bottom won't work
To Person who answered Best Solution above,
This worked nicely thank you.
After removing my circuit board the long silver strip was intact, however where it makes the turn about quarter inch, the solder or foil seam had a break in it which I filled-gap with solder.
My guess is if the "foil" or thin 2" long strip is serving as a fuse, it would still melt again even with my solder on the shorter section, in event of overload. Also seen on the plastic area directly behind where the circuit board would mount, and where the "foil" was blown, was a small blackened area as evidence of the blown foil. 2 new bulbs and all is well again Thanks!
Posted on Feb 09, 2008
SOURCE: ge profile spacemaker XL 1800 undercabnet microwave
hold down the clear/off button for 3 seconds and it will unlock..
Posted on Apr 15, 2008
IFIXALL
  • 868 Answers
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Posted on Sep 10, 2008
SOURCE: bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Posted on Jun 08, 2009
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
