Question about Amana Radarange Microwave Oven
What is the symbol --se-- on a amana serial number1000001gt radarange microwave oven mean
The symbol --se-- and none of the bottuns work
  • Amana Master
  • 9,085 Answers
"SE" means you have a defective membrane keypad.
With your full model number, I could have given you detailed instructions and parts numbers.
But without that, I'll have to just be generic.
If your model's membrane keypad is available as a separate part, that's usually the cheapest but most involved way to fix it.
Here is a handy guide with pictures showing you what's typically involved.
If it's not available separately, then you can replace either the control panel frame assembly, which comes with a new keypad on it, or the entire control box / controller assembly.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 17, 2013
MicrowaveSvc
  • 9085 Answers
SOURCE: I have an Amana Radarange
Is that model number RR-9?
You can find and order that part (# AP118264) here.
I just hope your magnetron is not blown, too. (Does it still heat?)
You can use a microwave-safe plate in the meantime.
Posted on Sep 01, 2008
  • 112 Answers
SOURCE: amana radarange microwave oven 1000 watts not heating.
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodes, and capacitor.
Posted on Oct 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave Not Working
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Nov 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Need to change bulb inside Amana radarange RR1220
There is an access / cover panel on the back of the oven.
It's shown in the exploded view here.
Please unplug the oven from the wall first.
Then use a 1/4" nut driver or socket to remove the screw in the end of the lamp cover.
The bulb is behind the cover, and should be readily available at grocery stores, home improvement centers, hardware stores and big box stores like Wal-Mart.
Posted on Dec 02, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: replace microwave light bulb
See page 24 of the owner's manual here:
Posted on Feb 08, 2009
Amana ACM2160AS microwave is sparking
If it is sparking dont use it check for any metal or tin foil in it if the is none replace it
would be cheaper than fixing
Feb 05, 2014 | Amana Radarange Microwave Oven
GE Spacesaver JVM1660WB turntable does not rotate?
My range works and oven lights? Does this mean that the problem is the Relay or the thermostat? The heating elements for the broiler/oven look fine and so do the connections?
Aug 16, 2013 | Amana Radarange Microwave Oven
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
I hit the lock button and it quit wrking
Hold down the "START" button for 5 seconds.
Jul 13, 2009 | Amana Radarange Microwave Oven
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Mar 17, 2009 | Amana Radarange Microwave Oven
Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
Jan 14, 2008 | Microwave Ovens
Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Nov 21, 2007 | Microwave Ovens
Amana Radarange Microwave Oven Logo
105 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
