Question about Philips 47PFL7432D/37 TV
The ambilite only works on the left side philips 47pfl7432d3
  • brennerg
    brennerg Jan 17, 2013
    i changed the 2 inverter boards and the rt side is still out
Ambilight Issue
Never do anything to this set now. Contact the authorized service center for Philips. Gopakumar Gopalan Google
Feb 25, 2014 | Philips 42PFL7332D 42 in. Flat Panel LCD...
Ambilight screen
Should be a back-light problem itself. If you wish to know more about the back-light system of this Philips TV, check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option. http://electronicshelponline.blogspot.com/
Jun 24, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
Left side does not work well
Even though the cable may be in perfect condition, there may be a bad connection
Jan 10, 2013 | Philips Tapster BluetoothStereoheadset...
+philips tv 47pfl7432d/37 left side is dark flickers on right side ambielt lights are lit on back of set
Sounds like you either have a defective LCD panel, LCD panel tab connection, or a LCD to T-con faulty connection. Does tapping or squeezing the left side of the TV change anything?
Oct 19, 2012 | Philips 47PFL7432D/37 TV
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
Smartimage problem on screen
Just hold the smart image button (last on left side of display)
I had same problem a second ago, so it worked for me.
Apr 14, 2010 | Philips 220CW8FB 22" LCD Monitor
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
Help
On Philips LCD and Plasma TV's you can center the picture left and right and also vertically. Use the round joystick in the center of the remote to see of you can shift the image to the left.
Dec 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 47PFL7432D/37 TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
