Rosetta stone windows 7 fatal error 1141
FATAL ERROR 1141
    Novelist:
  • 250 Answers
To fix this problem i would suggest to uninstall this software and scan PC with PC optimizer like Reginout to fix windows internal errors and corrupt registry entries.
Re-install the Rosetta stone. Disable Anti-Virus and Firewall before installing Rosetta Stone.
Posted on Jan 18, 2013
SOURCE: Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Posted on May 07, 2009
JaxPlanet
  • 922 Answers
SOURCE: when i try to install language disk i am getting
Well if it works in XP and Vista then it is safe to say it isn't compatible with W7.
Remember, Windows 7 is not going to be released for another 2+ months.
I have found a large number of programs that just don't work with W7.
Your best bet is to check on Rosetta Stone's website to find out if they list W7 as a supported OS.
Posted on Aug 23, 2009
laikexpert
  • 281 Answers
SOURCE: Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Posted on Jan 04, 2010
  • 10 Answers
SOURCE: rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Posted on Mar 03, 2010
SOURCE: Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
Posted on Jul 20, 2010
Fatal application 1141
Rosetta Stone Version 4 is compatible with Win 8. and Error 1141 is related to services in your computer i have found the fix at Questions Rosetta Stone Community
Apr 15, 2014 | Rosetta Stone 3 Filipino (Tagalog) Level 1...
Rosetta Stone fatal error 1141
Reinstall. Check your language - corrupt files usually give this error.
You might want to install CCleaner and clear registry. Here's the link for CC: http://www.filehippo.com/download_ccleaner/
Sep 25, 2012 | Rosetta Stone Spanish (Spain) v4 TOTALe...
Rosetta stone doesn't detect mic on windows 7
Hey,
I started to had problems with RS after I made some changes due to the error 2123, especifically, problems with the compatibility mode in RosettaStoneVersion3.exe
So. Go to Program Files-->Rosetta Stone folder-->RosettaStoneVersion3.exe. Right click on this file, Properties, Compatibility, and click on "Run this program with compatibility for Windows 7" (and check the box 'run this program as administrator').
I use Windows 7 x32. After this, RS came back to life, and I was able to use my headset with it too.
Hope it helps!
May 25, 2012 | Rosetta Stone V3 Spanish (Latin America)...
Fatal error code 2124 on Rosetta stone
There is file called tracking.db3 which gives us lot of error like 2124, 5611, 2123 etc.... you can find a perfect fix at Questions Rosetta Stone Community
Jan 03, 2012 | Rosetta Stone 1, 2, 3, 4 & 5 Set English...
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
Rosetta stone problem installing language discs
I just had the same problem. Rosetta Stone TOTALe French Level 1. I just ran it in Windows XP Service Pack 2 and it installed right away.
Apr 07, 2010 | Rosetta Stone Spanish (Latin American) -...
I installed Rosetta Stone and got the error 2123, is this a driver problem?
Hello my friend.Usually this error is cause because antivirus is blocking that program and usually bitdefender.So
1.Open BitDefender Antivirus in Expert Mode,
2.Click on the Antivirus tab
3.Under the Shield tab click on the Advanced Settings button.
4.Now add an exclusion for Rosetta Stone(click on + and find your program and click ok)
If you don't have bitdefender add an exclusion like we did with bitdefender for your rosetta stone
Feb 08, 2010 | HP Computers & Internet
or
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Error 2123 when i enter app
You may get this problem if you have BitDefender Internet Security. To fix it:
Open BitDefender, click Settings, set UI to Expert Mode. Click OK.
Select Antivirus, Advanced Settings then under Exclusions click [+] symbol, a browser opens, go to the following; C:\Program Files\Rosetta Stone\Rosetta Stone Version 3 and select the RosettaStoneVersion3 file, click OPEN. Then OK. Sorted.
May 03, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Computers & Internet Logo
724 people viewed this question
David Payne
David Payne
