hi . if you lay the machine gently on its back, unplug the mains cable to locate the pump follow the waste outlet through the body of the machine and you will find it, the will be water in there if the pump failed so with a bowl to catch the water drain in to the bowl then the pump can be removed with pipe grips for the wire clips and unplug the cable replce in reverse order be careful to make sure the hoses are on properly and the clips are seated be careful when lifting the machine upright the can be quite heavy, hope this helps
my whirlpool washer was doing fine my wife started another load then went to see if it was thru and...
(More)
my whirlpool washer was doing fine my wife started another load then went to see if it was thru and tub was still full of water and timer was in off position
My whirlpool washing machine purchased in 5/09 got out of order and not being repaired despite...
(More)
My whirlpool washing machine purchased in 5/09 got out of order and not being repaired despite repeated request to firm M/S Gautam Electronics,Reckong Peo,Distt. Kinnaur,H.P.(India)What should I do?
i dont hav any idea ..whats wrong with my washing machine, was ok. now since a week there seems some...
(More)
i dont hav any idea ..whats wrong with my washing machine, was ok. now since a week there seems some problem. i have check every thing bt can't figure out.. pliz help..
