I have Samsung Electronic NP355E5C-A01US win 8, operating system It can not recognize the dvd rom. what sould i do? I wanted to run win7 setup from usb flash drive but it didn't work. can not boo
I have Samsung Electronic NP355E5C-A01US win 8, operating system It can not recognize the dvd rom. what sould i do? I wanted to run win7 setup from usb flash drive but it didn't work. can not boot from the usb flash drive. please help me out.
I have the same issue but this is from the original O/S windows 7 recovery DVD that came with the system, I have the original DVD external DVD Rom Drive, it starts to read and just stops responding
Posted on Feb 25, 2013
  • 700 Answers
SOURCE: Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
Posted on May 05, 2009
  • 40 Answers
SOURCE: Installing Kingston 8 GB pen drive
It does not appear that kingston has released any support for its pen drives for windows 98. I would highly suggest upgrading your operating system. You may still be able to contact kingston, they may have a fix but it seems fairly unlikely.
Posted on Jan 25, 2009
  • 4 Answers
SOURCE: installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Posted on Jan 04, 2008
raja_ranidad
  • 6 Answers
SOURCE: How to Create multi-boot ( multi operating system ) dvd.
i use nero 6 but am willing to try other software if it'll work...
Posted on Jan 22, 2009
sodeep
  • 3267 Answers
SOURCE: On boot computer does not see Hard drives
Chose boot sequence to boot directly from the HDD . Also check if the Hard Disk is OK by connecting it to another PC. Check too that the power cables are snug tight and none of the pins are bent in the IDE slot. Now try booting first in safe mode & if successful go ahead and boot normally....sodeep
Posted on Apr 19, 2009
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
How to Load Vista or Win7 on a Toshiba Portege M400?
follow this steps
  1. You will find out that when booting your M400 from the Vista or Win 7 DVD, the setup program will not find your hard disk(s) The M400 has a SATA-RAID controller that doesn't have a "Vista Ready" driver! Use this driver
  2. Unzip the driver to a USB Memory stick and keep it ready for the disk management panel during setup
    • Use your Vista or Win7 DVD to boot
    • Stick the USB memory stick into any left hand USB port on your M400. you might have to try both ports until it is recognized by the setup
  3. Point to the memory stick when setup program ask you to load an external driver.
  4. Load the driver from USB Stick.
    • You should see the disk/partitions and should be ready to move forward in the installation process
Oct 20, 2016 | Computers & Internet
Hello and how are you doing I'm having a problem with the Samsung NP355E5C-A01US Laptop The bios has locked me out and I've been trying every other way to get into it or reset it I don't see a jumpe
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=44969&modelname=NP355E5C&modelcode=NP355E5C-A01US&session_id=Jclm2K8W8SJCx2nFXhQjM2t1KK51t3DZNSvLXlyYkHwNVBkrmbcw!-231341932!606653042!1411163558625&from_osc=
Sep 19, 2014 | Samsung NP355E5C-A01US Laptop
Laptop turns off and wont charge battery
Does it turn on while it's plugged in?
3 most common things that go wrong with laptop charging.
1- bad battery - replace
2- bad charger - replace
3- bad charging port - replace
Feb 26, 2014 | Samsung NP355E5C-A01US Laptop
Samsung Support Drivers
You can download the device drivers from the Samsung WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-.
http://www.samsung.com/us/support/
May 10, 2013 | Samsung NP355E5C-A01US Laptop
Laptop powers on but screen stays black
Possible cause's are disconnected video cable, bad inverter board, or the LCD needs to be replaced. Need more info for a better idea.
Apr 02, 2013 | Samsung NP355E5C-A01US Laptop
How do I down load Windows 2007 to my computer
First of all its not windows 2007, its Windows 7. There are two options. Both need Win7 CD/DVD.
1. if you have currently vista installed, you can upgrade it by inserting the win7 dvd and selecting upgrade.
2. If you want a fresh installation, make sure the win7 DVD is bootable. That means when you insert the dvd in drive and turn you system on, the DVD should start win 7 setup.
Step 2 requires that your first boot device should be the DVD ROM. If you dont know how to check or set this, please revert with what computer do you have. Make/Model.
May 25, 2011 | Microsoft Computers & Internet
SAMSUNG RV410/RY510/S3510/E3510 WIRELESS ADEPTOR
Note I was only able to get info on the 501.
http://www.samsung.com/us/support/downloads/NP-RV510-A01US
click drivers lower left. There is a 32/64 wireless driver there for both Atheros and Broadcom chipsets. They have both XP and Win7.
These drivers may work (no guarantee) for other models if yours is not the 510.
Feb 28, 2011 | Microsoft Windows 7 Home Premium 64BIT...
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
Aug 01, 2010 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
Computers & Internet Logo
1,110 people viewed this question
David Payne
David Payne
