Question about Sewing Machines
Top thread is breaking on Janome 6600P
Have checked bobbin; machine is threaded correctly; have changed needle. Was working fine while quilting 6 lap size quilts
  • 2 more comments
  • Barbara Jan 16, 2013
    I notice that the sewing line now shows 'skipped' stitches also
  • skipped stitches,,1.the needle is incorrectly inserted, bent or blunt 2.the needle or thread is not suitable for the work being sewn 3. a blue tip needle is not being used for sewing stretch,very fine fabric and synthetic fabric 4.the needle is not threaded correctly 5.a poor quality needle is used
  • Barbara Jan 18, 2013
    Thank you for all your help, after trying all your hints I decided to take it in for repair (The sewing machine hospital/urgent care). Will let you all know what I find out when I get it back in one and a half weeks or so. Thanks for all your help!
  • Sewing Machines Master
  • 7,365 Answers
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Posted on Jan 16, 2013
  • 1 more comment
    I have rethreaded the needle properly.
    I am over 1/2 way done when this problem occured so I can't see where it can be the tension. I have replaced the needle and made sure it is in correctly. When I tried sewing on a test piece it sews correctly but the minute I retry it on the quilt the thread again breaks..
  • try a different thread, it may be the thread is to light weight for the quilt.
4 Suggested Answers
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 8 Answers
SOURCE: I have a Janome 1600P
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Posted on Apr 21, 2011
  • 192 Answers
SOURCE: I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Posted on Nov 17, 2011
I have a janome 8200, when sewing the top stitch is perfect but top thread bunch under neath and no bobbin thread appears to be used, I have changed threads, bobbins and needle,
Be sure to use a brand new needle.
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. This allows the tension disk to release so the thread will seat properly. Verify that the thread path is correct.
Check that the bobbin is installed correctly (turning the proper direction in the bobbin case) and the bobbin case tension is threaded correctly.
Set the upper tension to the midway point. (This is the beginning point and may need tweaking later.)
Pull the bobbin thread to the top of the sewing project.
How and Why to Bring up the Bobbin Thread P.S.--this works with regular sewing, not just for quilting.
Lower the presser foot and test your machine. Begin sewing slowly.
If there are still issues--upper thread looping, try tightening but if it doesn't improve, the tension mechanism may not be working properly. Check and remove any thread pieces or gunk stuck in the tension mechanism. If still not working, it probably needs service.
If the bobbin thread is still not connecting with the upper thread, the sewing machine's timing is most likely off. (Search the internet for "sewing machine timing." There are multiple web sites and videos available that discuss this OR take it for service.)
Oct 08, 2016 | Janome 8080 Computerized Sewing Machine
Free motion quilting bobbin thread come to the top
check the timing between the needle and rotating hook also check the teeth for possible lost of timing maybe low or high to much.
Nov 06, 2013 | Brother CS6000i Computerized Sewing...
Janome 1600 thread shred and breakage
could be a bad section of the thread
check for burrs around the needle plate area and also in the bobbin
area and on the thread guide close to the needle.
Dec 09, 2012 | Sewing Machines
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Sep 12, 2012 | Sewing Machines
Janome sewing machine thread breaks while quilting
Check for burrs. Even the tiniest burr can break thread. Check the needle throat plate, the bobbin area...
Get out your magnifying glass and really inspect it. If you find a burr... carefully smooth it down with some very fine (1200 grit) sand paper.
Jul 20, 2012 | Juki Sewing Machines
I have a Janome 1600P DBX. The needle is installed correctly but the thread on top keeps breaking or skipping stitchings while free motion quilting? the quilt shop says it is not out of time. I have...
Apr 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
Top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
May 22, 2009 | Janome Memory Craft 9000 Computerized...
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
93 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
