Question about Magic Chef CAV4000AWW Top Load Washer
Snubber ring at the bottom of the washer there is a plastic Snubber Ring that is getting all torn up. I took the machine apart, replaced the part but it's still wearing down the ring and making a grinding type noise with the tub empty. Any ideas? All the springs are intact and in the correct place. Thank you!
  • hds63 Jan 25, 2009
    We did use an authentic part from the manufacturer to replace the worn out ring. Once it has been replaced, it is still making a strange noise and I don't want to actual put a load in until it's resolved. Thanks!
    The ring is at the bottom of the machine, there are no wheels that it rests on.
  • 37 Answers
Could you get some foam and tie it to the part that is tearing the Snubber ring.
Posted on Jan 25, 2009
    Genius:
  • 1,199 Answers
I woud say the rollers are worn out and causing this problem over again!
    President:
  • 1,214 Answers
Are there any rollers or wheels that the tub is supposed to ride on?
If the snubber is on the side, and not the bottom of the drum, then what is causing the excessive travel to cause the snubber to wear? Balance?
Posted on Jan 24, 2009
    Sergeant:
    Champion:
  • 435 Answers
Did you replace w/ an authentic company made part?
The tub on my admiral spins out of control hitting the walls of the washer and even moving the washer out of position
The problem i believe with your washer is a snubber ring. What is is and does is a teflon coated coated that fits between the tub support and the base frame ,both the support and frame are metal and during spin the tub has some movement espically during the high speed spin. This snubber fits between those two parts and allows the tub to move and is will slide around on this snubber.when that snubber has ground down to nothing when the tub moves it's not sliding on this snubber but grinding into the base and rocking the entire machine around,vibrating and walking all oveer the place(hehe..i seen one washer that had that snubber bad walk to the corner store and get a sandwich) Replacing that snubber will once again allow the tub to move freely and the snubber will asorb that movement,keeping the base solid and not rocking. To replace that snubber the entire tub asm. must be removed from the washer to replace the snubber
Gene
Aug 13, 2011 | Maytag Admiral AAV7000A
Tip
Maytag Washer Squeaking Problem
This advice is for certain Maytag TOP LOADING washers equipped with a vertical transmission and drive belt system.
Loud squeaking noises during the wash cycle or, at the end of the spin cycle, can be attributed to a worn snubber ring and/or brake assembly. The snubber is a plastic ring located under the tub support. It helps to reduce vibration as the tub agitates and spins. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is located to get rid of some noise related problems (this will be the round metal plate where the tub support meets the bottom casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking of the washer when the spin cycle stops. If the corn starch tip does not get rid of the squeaks, I would recommend replacing the following parts:
Brake Stator
Brake Rotor and Lining
Snubber:
You will need: Brake Removal Kit*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs brake spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
The parts required to make the repairs aren't very expensive, but the tool required to do it can cost about $100. This repair I would rate as DIFFICULT for the average do-it-yourselfer. If you've never worked on this type of washer before, this is not a job that I would recommend. However, Maytag DOES provide informative how-to instructions with all their parts.
To replace the snubber and brake assembly:
1. Remove the front case of the washer to access the washer interior.
2. Tilt the washer towards the back and remove the drive belt. Slide the drive motor towards the center pulley to relieve belt tension.
3. Remove the drive pulley by removing the center cap and retaining ring from the drive shaft. Remember how these components go back together. There should be a couple of plastic drive bearing pieces and some metal washers above the pulley on the shaft.
3. Lower washer and remove hoses from the wash tub.
4. Remove the suspension springs. NOTE: Pulling the wash tub towards the spring you are removing will release some of the tension on it.
5. I usually remove the entire wash tub with transmission still installed at this point and place it upside down outside the washer for ease of accessing everything. (There are other methods, but I find this one easier).
6. This is where the brake compression tool will be required to remove the brake rotor, stator and snubber ring. (Instructions come with the tool). Basically, it involves compressing the spring by turning the compression tool CW with a wrench, loosening all the bolts on the brake stator housing, and then slowly turning the compression tool CCW.
7. The brake compression tool is removed at this point and the snubber, brake rotor, brake stator and brake spring can be accessed.
8. Replace any worn parts, and reassemble the brake assembly. DO NOT forget to place the brake spring back in place before putting the brake rotor back on.
9. Place the tub assembly right side up and lower back into washer.
10. Reconnect all hoses back to wash tub.
11. Reinstall all tub suspension springs. NOTE: It’s easier to start in the back of the washer and work your way towards the front.
12. Tilt washer back and reinstall drive pulley. NOTE: When placing drive pulley back on shaft turn pulley slightly to ensure it is seated all the way on the shaft. NOTE: If the shaft had multiple metal washers, you may only need ONE after replacing the snubber ring. Retain the extra washer for later use if needed. If the drive pulley is reinstalled correctly, a groove will be visible at the end of the drive shaft for the retaining ring to go back in place.
13. Reinstall drive belt.
NOTE: The following link lists the recommended tools to complete this repair:
Spring Removal Tool (item #455570)
Brake/Bearing/Seal Removal Tool Kit (item #997909)
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Just go to these fields and select the following:
Brand: Maytag
Appliance Type: Washing Machine
Part Type: Tool
The list of all Maytag tools will appear.
NOTE: To save a few extra dollars, you can remove the 6 10-24 machine bolts, that hold the brake stator housing, one at a time and replace them with 10-24 x 2" machine bolts. Once all the original bolts are removed, back out the 2" machine bolts evenly, keeping the brake stator housing aligned but slowly releasing the pressure from the 200 lb spring.
After replacing the snubber ring, the brake and the brake stator housing, use the 2" long machine screws again to pull the unit together. Once all assembled, replace the 2" bolts with the original 10-24 X 1/2" machine bolts.
I hope this information is helpful.
on Dec 04, 2009 | Washing Machines
Tip
Brake Stator
Snubber:
I hope you find these instructions helpful.
on Feb 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My Performa goes out of balance quite frequently. Does that suggest a problem with the machine?
That machine was made by crosley it would have at the bottom stucture a snubber ring that becomes wore and reduces the tension on the 6 tub springs . That is why the machine will start to shake..The repair use putty knife there is two spring catches under the front just above front panal push knife in when you find clips top of washer should hinge up..The frount panal has two bolts down through on each side remove them.The front should lean forward and lift of the two retaining clips at the bottom. look for white power that will be signs that that snubber has wore ...If you make that assumption then we will go further on how to replace snubber ring///Note i always replace the 6 spring with the snubber ring .if not the old springs will let the tub move around and cause snubber to wear early.. If I helped you please vote if you need more help please ask ....good luck
Feb 06, 2011 | Maytag Performa PAV2200
Goes of balance in spin cycle 90% of the time
I found one of my motor mounts loose. The unbalance cracked and broke the base of the washer. I found this when the machine stopped spinning. I am replacing the base(expensive) and transmission pulley. The motor mount is on the front right bottom. You may find the same when you tilt the washer back. I would tighten it up now!
Mar 13, 2010 | Maytag Performa PAV3200
Clothes must be perfectly balanced or washer will shake and walk
The snubber ring needs to be replaced. It's not an issue of balancing the clothes. The ring is plastic and wears down. Are there white plastic shavings under the washer? Those are from the ring. You can order it on PartSelect.com, and there are instructions on how to replace it.
Apr 25, 2009 | Maytag HAV2557 Top Load Washer
Easily off balanced
bad snubber ring, after a while especially if you have heavy loads your snubber can get worn out and the machine will go off balance VERY EASILY. the snubber lies beneath the whole transmission assy, it is usually white in color a moderately big repair job, there are shortcuts but too lengthy to go into here.
Apr 06, 2009 | Maytag MAV3905EWW 13 Cycle Washer
My maytag washer won't turn or spin..
Brake Stator
Snubber:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 03, 2009 | Washing Machines
Maytag Atlantis Washing Machine
The loud squeak at the end of the spin cycle is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking (causing movement of the washer) went the spin cycle stops. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself. NOTE: There should be a warning label explaining this
You can find all your parts and information at repairclinic.com. Just type in your model number in the search menu.
The parts required to make the repairs aren't very expensive, but the tool required to do it can be a bit pricey. If you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good about providing the necessary instructions with their parts, however.
In summary this job involves the following steps:
1. Removal of the front case to access the washer interior.
2. Removal of the drive belt and pulley from underneath the washer.
3. Removal of the drain hoses from the wash tub.
4. I usually remove the entire wash tub with transmission still installed at this point and place it upside down outside the washer for ease of accessing everything. (There are other methods, but I find this one easier).
5. This is where the brake compression tool will be required to remove the brake rotor, stator and snubber ring.
Now, I am summarizing this job quite a bit. If this is something you wish to try to repair yourself, and you need more instructions, let me know. I hope this helps you.
Off balance during spin cycle
I have a Performa Model PAV3200AWW that would go unbalanced every time it would go into a spin cycle. I found the problem to be a worn out snubber. This is a plastic ring that is at the pivot point for the whole tub. It separates the metal to metal contact at the bottom of the washer pivot point. The part is less than ten dollars, but it is a quit a job to replace. I had to remove the whole tub to replace mine, but it did solve the problem. If you see a lot of plastic shavings around the pivot point, then this could be your problem.
Oct 17, 2007 | Maytag Performa PAV2200
Magic Chef CAV4000AWW Top Load Washer Logo
185 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
