Question about Foxconn Computers & Internet
Jumper chart for DG33m04 MB - Foxconn Computers & Internet
  • Mitchel Porter
    Mitchel Porter Jan 17, 2013
    I got front panel connector problem fixed, Thx
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Foxconn Master
  • 2,226 Answers
Http://www.foxconnsupport.com/Default.aspx?Language=en-us
Posted on May 26, 2014
2007 mercedes benz gl450 fuse box
Most charts can be found printed on inside of fuse box cover. Red.
Apr 05, 2014 | 2007 Mercedes-Benz GL450
I need a copy of fuse box chart for mb s320 year 2000
The original fuse diagram was wrapped around a tool in the trunk kit of the vehicle. Why???
Follow this link for a fuse chart on a 220 s class year 2000. Yours should be similar.
http://www.benzworld.org/forums/w220-s-class/1219691-fuse-chart-2.html
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | 2000 Mercedes-Benz S-Class
How to do jumper setting on RAM upgrade from 2 x 256 MB to 2 x 512 MB.
Good day,
Theres no need to jumper anything in upgrading your Ram, Just remove the 256 mb rams and replace it with your 512mb ram. Then try turning your PC on.
Feb 01, 2011 | Acer Aspire SA20 PC Desktop
Motherboard 277498-001 setting jumpers - help please
Visit http://www.compaq.com and select the product then download the user's manual. Such informations are usually given in the users mnual. Although Compaq is presently owned by HP, but user support is still there. (ehteshamhusain@gmail.com)
May 16, 2009 | Compaq ( 277498-001) Motherboard
Epox motherboard and SATA disk
According to the hard drive manufacturer Maxtor, motherboard host controllers using the VIA and SIS chipsets VT8237, VT8237R, VT6420, VT6421L, SIS760, SIS964 found on the ECS 755-A2 manufactured in 2003, do not support SATA 3 Gbit/s drives. To address interoperability problems, the largest hard drive manufacturer, Seagate/Maxtor, has added a user-accessible jumper-switch known as the Force 150, to switch between 150 MB/s and 300 MB/s operation.[9] Users with a SATA 1.5 Gbit/s motherboard with one of the listed chipsets should either buy an ordinary SATA 1.5 Gbit/s hard disk, buy a SATA 3 Gbit/s hard disk with the user-accessible jumper, or buy a PCI or PCI-E card to add full SATA 3 Gbit/s capability and compatibility. Western Digital uses a jumper setting called "OPT1 Enabled" to force 150 MB/s data transfer speed. OPT1 is used by putting the jumper on pins 5 & 6. http://en.wikipedia.org/wiki/Serial_ATA
Dalius
Mar 30, 2009 | EPoX EP-8K9A7I Motherboard
Jumper placement
Look at the chart printed on the drive itself. If there is no chart, post what drive model it is and whether you want master or slave position. You do have an IDE drive, don't you?
Jan 19, 2009 | Maxtor Hard Drive
No External Speaker Sound
Hi jdnimrod,
This is not you're first post about the Foxconn mother board.
You have an issue with the PS2 keyboard as well. This Foxconn model ( 761GXK8 you listed ), is not 100% correct.
Please check this link:
http://www.foxconnchannel.com/EN-US/searcher.aspx?key=761GXK8
Find which is you're board.
Than post back into this answer.
It is important you run the exact CPU that is compatible with the mother board.
Foxconn's Compatibility chart for MB to CPU.
761GXK8MB-ERS/EKRS
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606271133082354761GXK8MB.htm
761GXK8MC-RS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200603210922432734761GXK8MC-RS.htm
761GXK8MB-KRS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606300744394666200606271143263290761GXK8MB[1].htm
I'll help you further once I know the correct mother board.
Mike
Aug 08, 2008 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
EPSON RX600 PRINTER
Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
Please use this chart as a general guide line.
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
Compact Flash 4 GB
Secure Digital 1 GB
Sony Memory Stick 1 GB
MagicGate Memory Stick 128 MB
xD Picture Card 512 MB
Smart Media 128 MB
Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
sorry for this one :(
Apr 18, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Jumper settings for a Maxtor hard drive, Model 87000D8
Here's the chart that lists the jumper settings for all of the various models of Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
The first drive above is a DiamondMax 1750, and
the 2nd is a DiamondMax 4320
Feb 08, 2008 | Maxtor Hard Drive
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Computers & Internet Logo
76 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
