Question about Element Electronics FLX-3211B 32 in. LCD HDTV
Schematic how to remove the back
  • Element Elec... Master
  • 933 Answers
It's a pain on this set, ironically I just got finished repairing a backlight problem on this same set. If the pedestal is attached, you will have to remove those 4 bolts. Then there are 9 outer screws around the outer sides of the frame, remove them. Then there are 6 bolts towards the middle (in deep holes). You will also have to remove the plastic cover just above the video connections. This plastic cover is held on by two screws. Once you remove the screws to the cover, slide it down then lift off, it should come off. At this point the back cover should come off. To access the main board and the power supply/inverter, you will have to take the cover off the silver box. You will have to lift the silver box out of the TV but be careful, there are wires attached at the bottom.
Posted on Jan 20, 2013
Im taking out a switch in a four switch circuit
If you are planning to put 4 switches back in after the renovation, you need to make a wiring schematic of exactly how they are wired now and label each wire according to your schematic. Then when you put them back, everything will work. If you are going to use less light switches then the schematic will help with a smaller number of switches. These are 3-way switches, for your information, not regular 2-way switches!
Jan 02, 2013 | Dryers
WHERE CAN i GET A SCHEMATIC DIAGRAM FOR A wHIRLPOOL dISHWASHER MOD ADG 644 NB
Schematic SHOULD be located either on the back of the dishwasher itself, like a decal........ or under the front door panel (the sheet metal panel which covers the front of the door), remove he front cover and take a look there, manufacturer usually applies schematic via a decal on each unit to assist field service technicians. PLEASE NOTE>>>>> DISCONNECT / SHUT OFF POWER TO UNIT PRIOR TO SERVICING!!!!! (Turn OFF Circuit Breaker) Hope this Helps You find it! GOOD LUCK!
May 29, 2011 | Dishwashers
Anyone have the wiring Scematic for Hobart 2912 Slicer
Schematic is located on the back side of the bottom cover. Tip the slicer back and remove the bottom cover to find it. It's usually very dirty with food and, more importantly, oil. Be careful wiping oil off as the schematic often times smears when doing so.
Oct 25, 2010 | Hobart Slicer Automatic 12"
Washing machine spins but wont drain
Spinning is from one motor. Draining is from a smaller motor ( pump). The problem is from the pump. Accessing from the back after removing the panel, unplug the pump connectors to measure resistance to see if there is continuity. If not then the pump needs to be replaced. If there is then need to trace the schematic back to the controller. The schematic is in a small plastic bag attached at the time controller.
Jan 09, 2010 | Tecnik TKL9260 Front Load Washer
Need free download schematic of JVC GR-DF 450 Mini DV camcorder
After careful inspection, a hard rubber roller that is part of the tape take up mechanism, has fallen off. Located and removed from casing. Still need schematic of JVC GR-DF 450 Mini DV to secure roller back on.
Aug 25, 2009 | Video Cameras
How to attach the head back on Oster Classic Clipper
I dont know what model you have, so I have included the master schematic link. When you goto the link posted, click on you model for the schematics.
http://www.clipperrepair.com/inventory.htm
Dec 10, 2008 | Oster 76076-010 Hair Trimmer
Where can i find schematic diagram of whirlpool refrigerators?
there's no cool air coming into the freezer or refrigerator sections. as soon as it starts there is a clicking sound and it stops. what's the problem? the fan works at the back. i've cleaned all the coils below. thanks
Dec 09, 2008 | Whirlpool GD2SHGX Refrigerator
Can't find schematics for Kenmore dryer model #110.60712990
Have you checked inside the control panel? The manufacturer normally places a schematic or block diagram inside the operator console for use by repair technicians. Just remove the screws on the back of the console and there should be some tech info inside.
Aug 27, 2008 | Dryers
Need schematic to remove top
No schematic needed.
Unplug washer
on the bottom of the control panel remove two screws, one on each side.
control panel flips up and over self.
Now on each side under control panel are gold colored clips to remove cabinet from back panel. use a screw driver and release clips,
unplug any wires going to top panel from rear panel that make hold back cabinet,
Cabinet pivots on locator pins on lower front of base. Now with cabinet removed, top can be removed from cabinet shell
Jul 15, 2008 | Whirlpool Washing Machines
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
