Washing machine stuck on drain cycle how do i reset it?
Washer/dryer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
May need a timer motor if you can advance it manually
Posted on Jan 16, 2013
  • 185 Answers
SOURCE: Brandt washing machine gets stuck at rinse
check the coupler it might be the timer
Posted on Mar 25, 2008
freetek
  • 5568 Answers
SOURCE: will not drain after the wash cycle, will not enter the rinse cycle
In my opinion, you will need someone on site to find whether the program switch has failed or it is only the pump itself.
The former is quite expensive but the pump shouldn't cost more than $20-30 plus labor.
When you write 'does not respond,' do you mean it makes no noise at all or just doesn't pump?
If it makes no noise, it is likely the program switch.
If you can determine that it is the pump, this is often a fairly accessible and simple job not requiring a lot of tools.
Keep a mop handy though . . .
Posted on May 01, 2008
  • 240 Answers
SOURCE: roper washing machine
does it spin? drain pump is directly mounted on motor, works in spin. may need new pump. Whirlpool standard pump.
Posted on Jun 03, 2008
  • 5 Answers
SOURCE: ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Posted on Aug 03, 2008
shinn8
  • 85 Answers
SOURCE: washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
Posted on May 18, 2009
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Splendide 2000S Vented Washer/Dryer makes a bad noise once in the rinse cycle and water will not drain
Check the drain pump. There may be a coin, hairclip , button etc stuck in the blades of the pump. If the machine cant pump out, it wont go through the cycle.
Sep 17, 2017 | Splendide 2000S Vented Washer/Dryer
Frigidaire washer does not drain
Remove the drain hose from sink Unplug machine Safety 1st....put hose over bucket should gravity drain next take out the filter if its got one bottom /right hand side of machine clean...if not locate drain pump and remove blockage...kids sock maybe? Door may reset after water has been removed and unplugged .Good luck
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
My washer won't drain
Check the lid switch, usually the drain cycle is where it shuts the machine off if the lid is open.  If not the lid switch, probably the pump, or something stuck in the pump
Dec 04, 2009 | Frigidaire FEX831CS Top Load Stacked...
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
