Question about Dryers
Frigidaire affinity error code 68
Dryer runs, after a few minutes, error code 68 flashes and beeps...unplugged, tried again, same...any suggestions?
  • 314 Answers
What is the name and model of these dryer.rate these for clean solution
thanks
Posted on Jan 16, 2013
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
SOURCE: Frigidaire Affinity Front Load Electric Dryer
I have a totally unrelated solution. Remove your lint filter. Now remove the waffled plastic that covers the lint filter slot. Hint, its inside the dryer, and there's two screws holding it in. Be careful, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is either the temperature or moisture sensor, I bet. Don't drop the screws into the lint filter slot. If yours is like mine, you'll find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint, and reinstall. While you have it opened up, stick your vacuum's crevice tool down inside the lint filter slot and clean up all the lint in there as best you can. Problem solved. I think the build of of lint was shorting the two contacts, and this was screwing up the electronics.
Posted on Jul 03, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer error 68 and hot to touch
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
Jul 26, 2014 | Dryers
I have a frigidaire affinity that is beeping with code E68 HELP???
Good Morning Friend,
I understand that your Frigidaire Affinity dryers is beeping and displaying an E68 code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
How to get the error code test on Frigidaire affinity model FARE1011MW
Good Afternoon Friend,
I understand you are receiving an error code on your Frigidaire dryer, model# FARE1011MW. I see that when you press the start button, your dryer beeps and the drying light begins flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
My frigidair affinity dryer wont start it just beeps
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
Affinity dryer will not start beeps three times
I understand that your Frigidaire Affinity dryer, model# ATF7000E, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home'sicon1.png circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 29, 2014 | Frigidaire Affinity ATF7000E Front Load...
My affinity frigidaire gas dryer wont stop running
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Apr 12, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
My affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryers Logo
159 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
