Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV cover removal
I have a blinking standby lamp. If someone knows the meanings of these codes, I will say what the pattern is. But my main query is how toget the cover off! I have removed 5 clearly marked and accesible screws aroubd the case. There are 2 arrowed holes at the top of the cover. These are a very small diameter and seem quite deep, and there is no visible screw. Poking a screwdriver down them does not seem to find a screw head.
I think the actual fault may be just a loose board or connection,as I have just moved the TV 10 miles.
Can anyone help with advice on removing the cover?
Note the product name is above, it would not allow me to enter this number.
I always thought that the arrows on Sony equipment were to indicate the fixing screws. It turned out that the two arrows at the top of the case (see my query) were NOT fixing screws but clips. Having removed the 5 marked screws and then manouvring the cover, it eventually clicked off the clips.
After wiggling all the boards around, the TV then worked again, but it took about 2 hours to get the cover back on, as there were so many things to line up, and as one side got into position, the other side popped out again.
If anyone can supply the meanings of the flashing light codes for this set, I would be grateful in case the fault happens again.
The TV is a Sony KV-29X1U (this website would not let me type this in to the right box, it said it was not a valid product).
Posted on Jan 25, 2009
The power/standby light blinks red three times pauses then repeats on my Sony KDF-E42A10 TV... no power Thanks
Please make sure lamp cover is fixed properly as it was removed to replace/ check lamp in tv.
If lamp cover is not fixed, tv will not turn On and red light will blink 3 times.
Thanks.
Apr 28, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have a Sony 50" LCD projection TV. It's slightly older than 4 yrs. now. My problem is the Power/Standby light blinks green when I try to turn the set on, which is typical, but the picture only comes on...
A four flash error sometimes means one of the fans is bad or clogged so much it won't rotate. You probably will have to remove the back and visually see if the fans that are visible are rotating. There is also the main lamp fan that is located in the housing to the left as you take the back off. This fan is not easy to get to at all as it requires a bit of a tear down to get to.
Sep 16, 2010 | Sony KDS-R50XBR1 50" HDTV
I have replaced the lamp block and now the power stand by red light is going on and of (this was a new lamp block). Do I need to reset some how?
If standby red light is blinking 3 times after three second pause then check lamp cover that has no been fixed in its place correctly, it is first thing that you removed from tv cabinet to replace lamp, make sure lamp cover is back in place properly and tight.
If standby red light is blinking more or less then 3 times, let me know to diagnose problem.
Thanks.
Sep 04, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No video no sound red standby light continous blinking once per second
Red Lamp light might be blinking in your TV, that means TV needs new lamp as existing lamp inside TV is broken or dear.
Please replace lamp in your Sony KDS-55A2000 TV and lamp replacement procedure is written in user manual.
Let me know if you need user manual copy.
Thanks.
Oct 02, 2009 | Sony KDS55A2000 55" HDTV
KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Standby red lamp on my KP-51W5510 blinks in an 8 blink pattern
Try this first HOLD DOWN THE RESET on the remote while pressing the power button on the TV.
If this does not restart it one of the IC chips has failed and it will require repair
please rate this help top keep our service online
Aug 17, 2009 | Sony Grand WEGA KDP-51WS655 51" Rear...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
