Stuck on drain cycle how do i reset it? - Washing Machines
  • papartington
    papartington Jan 16, 2013
    dosent do any thing when u move dial
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Might have a bad timer motor and its not advancing if you advance it manually and it works that might be the problem
Posted on Jan 16, 2013
Opened dishwasher just as it filled up to put in another glass, now the dishwasher won't wash or drain. Power button won't cut off or reset cycles. Turned off breaker, but still stuck on same cycles
You don't mention what make/model of dishwasher. Some diswashers, like my Bosch, require a reset procedure to "kill" a cycle that you've already started. They don't like to have the power button pressed during the cycle. The procedure to reset varies by make and model. If you have the owner's manual, you may check in there for the procedure.
Oct 15, 2016 | Dishwashers
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Dishwasher will operate only 10 min before stopping cycle
Check for places food could get stuck and clog the workings, including the drain hose.
Nov 24, 2013 | Kenmore 24 in. 16302 Built-in Dishwasher
How do i reset my whirlpool adg 7460 dishwasher ? programme seems stuck on end cycle?
Unplug it, move timer to start and plug back in. If it still seems stuck at the end it is almost certainly the timer. If it starts as normal, suspect the drain pump or pressure switch
Apr 22, 2012 | Dishwashers
The dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Feb 21, 2010 | Bosch SHX46L1xUC Dishwasher
Gets stuck on timer and wont count down
We had a similar situation with our LG washer. It was not a timer problem.
The machine was not entering the spin cycle and was just stuck in limbo. A sensor or something was not being satisfied and allowing the progression to the next cycle. Our problem had to do with the drain line; it seemed as if it was air locked?? After lowering the drain line height (to reduce the head pressure), and manually draining some water out of the drainage cap (where the strainer is located) onto the floor, the sensor became satisfied and the machine completed its cycles properly.
What told me that it was not a timer issue was the fact that on different wash settings (normal, heavy, quick cycle), the machine timer would get stuck at different countdown points (22mins, 12mins, etc.).
Jan 17, 2009 | Washing Machines
Stuck on SUDS
my wife runs into the same problem, sometimes she reruns the cycle and sometimes it continues itself. i am presently trying to solve it. she thinks it might be the detergent, she is useing gain powder and liquid.
Sep 22, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Will not shut off at end of the drain cycle
there should be a float behind the fill valve with a magnet in it which operates a reed switch. This switch keeps the pump running as long as the base has water in it or if the float is stuck on the up side (and makes the pump "think" that there's water in the base). Check this float to see if it's stuck and release it so it could tell the pump when to stop draining. Hope this solves your problem.
Jan 31, 2006 | Bosch SHU9916 Dishwasher
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
