Question about Crosley 1950 Vintage Shelvador Refrigerator Print Ad
My 1950 Shelvadore freezes everything. I don't know what it is causing it?
I can't find any repair people in my area that are able to work on it.
Blank white screen
Karim, read follow :
identifying problem : this is sound me hardware problem,on LCD area; Causes :normally this happen by water damage ,
Solution :
Clean with alcohol the LCD area on board, and let it dry for 4hours, it will start working normally.
Material need :
screw drivers tools for device, Brush,and alcohol.
Notes:
if you don't know how to assembly and dissembly the device search on you tube.com but if are you not able to do this at home, please don't try without supervision of technician,give some official repairer to fix for you.
Jul 16, 2012 | RIM Blackberry Curve 8900 Smartphone
MY BLACKBERRY PHONE CURVE 9300 STROLL IS NOT WORKIN AFTER TRYIN TO UN LOCK WHAT CAN I DO?
Alice, read follow :
identifying problem : this is sound me hardware problem,on scroll area; Causes :normally this happen by water damage (because of wet finger touching), Solution :
Clean with alcohol the scroll area and keypad area on board, and let it dry for 4hours, it will start working.
Material need :
Notes:
Jul 16, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
I mean it freezes EVERYTHING. Pop, water, juice, top or bottom. I have unplugged it overnight, no change. It is the thermostat. I just don't know where to get one.
Please repost this in the appliance area dealing with this type of equipment as for some reason it is posted in the TV area.
Jun 14, 2012 | Sylvania Televison & Video
My refrigerator has started getting items freezing in the upper compartment. I have it set at 39 degrees in upper and 0 for the freezer. everything seems to be working fine but I'm getting lettice and...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 09, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
I get vapor lock everyday in my 1992 buick grand margui v8 especially in the simmer here in las vegas. Whar do I do to fix it? What causes it please!
How would you know that you get vapor lock?
We don't live in the 1950 or 1960's any more
Explain what the drivability issues your having are
& what has been done to diagnose it
Jul 04, 2011 | Buick Rendezvous Cars & Trucks
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
Broken water line or water heater, from winter freeze. When water is turned on tap water goes under the bunk bed area. Could this be the water heater or a hose in the area. We don't know the layout...
Depends on which tap you're turning ON. If it's cold water tap, it's probably a water line. If it's the hot water tap, it could also be a line. As heaters leak, whether the water tap is ON or NOT. Opening a tap valve doesn't cause the water heater to leak. The main question is, was the water heater's tank drained, before the Winter Freeze, when no one was using it? If it wasn't, there's a good chance the water heater will leak too
Hope this helps you solve the leaking water pipes problem. Please let me know Thanks.
Jun 15, 2011 | Heating & Cooling
My land rover d2 wont start i put a new ckp sensor and plugs and wires but it still wont start .. the next step is to buy the coils
The first step was to go to a repair shop
that has people knowledgable enough
to diagnose any issues you were having
You chose to throw parts at it.
That worked in the from 1950 thru 1980,
no more.
If you don't know the technology & how to
test it,leave the hood closed
May 29, 2011 | Land Rover Discovery Cars & Trucks
Engine coolant is leaking thought flywheel on my 1995 mercury cougar. Can this problem be fixed?
The most likely cause of this problem is a leaking freeze plug located in the rear of the engine block. The problem can definitely be fixed. Unfortunately, it's probably not going to be something that can be done quickly and easily and it might require removing the engine in order to gain access.
I don't think block seal will work in this case. Although this job is not impossible for someone to do themselves, it's best suited for someone who has a mechanical background. If you don't have experience in this area and you decide that you want to do this then please be very careful and remember that there are hidden dangers inside that engine compartment for someone who does not have experience in this area. Do not remove fuel or AC lines if you don't have experience in this area. I hope this information has been helpful and thank you for using Fixya.com.
May 28, 2011 | Mercury Cougar Cars & Trucks
Crosley 1950 Vintage Shelvador Refrigerator Print Ad Logo
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
