Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Cannot connect our replaced xbox live to internet via router although it connects directly from modem.
  • 49 Answers
Call your Xbox manufacturer and asked them about the port# that needed to be open on your router. Once you have the port# asked your dlink manufacturer to opent the said port for your xbox.
Posted on Jan 24, 2009
Cannot connect to xbox live
Try this:
-If it's failing the IP test, that would imply that it can't talk to your router, not the internet, since that's where it gets it's IP address from. (Although XBox may do this with an internet check) So:
-First, have you tried a different ethernet cable to the XBox; one that you know is good?
-Secondly, ports on the switch can go bad without the whole switch failing. Have you tried plugging it in to a different one in the router?
-Assuming you have a dynamic service such as a cable modem, have you tried plugging the XBox directly into that modem wire coming out to the router?
Be sure to power cycle the XBox on each of these checks so you remind it to go out and check for a connection.
Hopefully this helps!
May 10, 2011 | Microsoft Xbox Live 12 Month Gold...
We recently got an Arris TM722 modem and a netgear wireless-N 150 router WNR 1000 after getting a new ISP. My problem is that every time I turn on my xbox to connect to xbox live, my xbox doesn't connect...
Recheck your settings on the xbox.
If using wifi on the xbox, you'll have to setup a new connection to the new router.
If the xbox is wired via cable to the router, you may need to add a router password or other settings .
Jun 21, 2017 | Computers & Internet
Wont let xbox live update i checked connection and it was fine
If your Xbox 360 console is connected to the Internet through a router or gateway (as opposed to through a direct modem connection), try connecting the console directly to the modem. Here's how:
  1. Plug one end of a network cable into the back of your Xbox 360 console and the other end into your modem.
  2. On the console, sign in to Xbox LIVE and start the game.
  3. Choose to download the game update.
If you can download game updates when the Xbox 360 console is connected directly to the modem, there might be a problem with your router or gateway configuration.
Cheers!!
Nov 01, 2010 | Microsoft Xbox 360 Console
My router can no longer connect to my xbox live. It began as a problem where i had to restart my modem in order to get connection on either my laptop or xbox but now, only my laptop can be connected to the...
you need to register the router to your internet provider so that the modem will always give an internet connection to the router even if the router will be reset.
from that the xbox should follow through and connect to xbox live if you have an open NAT type.
Sep 14, 2010 | Linksys WRT160N Wireless Router
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
Similar problem restated: Xbox live won't work
why would you eneter the same mac adress as your pc?
Apr 08, 2009 | Microsoft Xbox 360 Console
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
Xbox live
2 Solutions-----
Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
This will probobly be free, but if your charged, it will be a small fee.
Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
Results should come up (for wired router)
Network Adapter - Wired
Wireless Network - (Left Blank)
IP Address - Confirmed
DNS - Confirmed
MTU - Confirmed
ICMP - Confirmed
XBOX LIVE - Confirmed
NAT - (either moderate, opened, or strict)
If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
If results come out to be
''Network Adapter - Disconnected''
After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
Sorry it took me so long to explain that, but i hope it helps you.
Best of luck
-Erk
Jun 18, 2008 | Microsoft Xbox 360 Console
Xbox360
Hello taz1028,
In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
Sincerely,
Agent Xiong
May 31, 2008 | Microsoft Xbox 360 Elite Console
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
