Question about True T-49 Side by Side Refrigerator Commercial
Moisture/water buildup I have a T-49 and the interior seems to be "moist". Condensation beads on milk jugs, and on the shelf racks. We get mildew/mold very easily and have to sanitize the whole unit and start over. Same problem time after time. I checked drain lines - seem clear. By definition, the firdge should be drying the interior air as it cools. We're not putting in open containers (i.e. sources of moisture), so I'm not sure what to think. Ideas?
  • 51 Answers
It sounds like your T-49 is not maintaining a low enough temperature. I would put a mercury filled thermometer inside and monitor the temperature. Your unit should maintain a temperature lower then 40 degrees Fahrenheit. I usually set the units I work on to come on at 39 degrees and turn off at 33. The moisture should condense on the coils.
Posted on Feb 20, 2009
Does a keurig 60 coffemaker build up mold in the main compartment
Yes, mildew and mold can build up in any coffee maker, including Keurig. You should run several cycles using white vinegar instead of water. Allow the vinegar to fill and sit in the machine before expelling it. This should be done every couple of months to prevent sediment buildup and mold and mildew. You should not use bleach or something else that is not safe to ingest.
Jan 26, 2016 | Logitech Computers & Internet
I have painted the wallpaper in my kitchen about three times about two years ago I used Dulux matt dark streaks have appeared on the outside walls condensation marks? the paint looks chalky do you think...
There are 2 types of paint I do not like, Behr and Dulux. Buy Benjamin Moore for best results. Painting wallpaper is not advised, if it is not adhered on well, you can have trouble. Streaks could be condensation, especially in a bathroom, a kitchen can also be damp because of boiling pots. Warm moist air condenses on a cool object. It could be the wall paper is losing adhesion. Check to see if the paper moves a bit when pressed. Remedy is remove the wall paper and repaint. Get all the glue off, scrape it after soaking the wall. Sand the wall, wash with TSP, rinse with clean water. If you don't do this, you will get a lousy paint job. You would be best to prime then top coat. Alternately get a paint that is self priming. In a moist area use Zinnser
Home Hardware Paint Dcor
Zinsser 1 gal Perma White Mold and Mildew Proof Satin Interior Paint 2...
Mar 02, 2015 | Miscellaneous
Mildew in washer
Hi Meredith, this is AP!
I understand you are struggling with mold spreading in your Frigidaire dishwasher, model PLD2560LCC. The average useful life of a dishwasher is about 13 years, so I would attempt to get a few more years from the dishwasher if you can. Chlorine bleach kills mold and helps remove most mildew stains. Dilute 1 cup of bleach in a gallon of water and scrub the interior of the machine with a stiff brush. Use a toothbrush to get in narrow areas, such as around door gaskets. Wear gloves to protect your hands when you use bleach, and also avoid mixing bleach with any other cleaning product. Run the dishwasher empty after cleaning it to rinse out the bleach residue. If stains remain after mold removal, scrub them away gently with a damp rag and mild scouring powder.
Or you could run a cycle with no dishes. Once the dishwasher has completed its initial fill, add 1 cup of white vinegar and complete the cycle. If you find that removes the mold I would open the dishwasher door after each use and allow it to dry out completely before closing it to prevent mold growth. Moisture, bits of food and a warm environment can lead to unwanted mold growth. If you won't be using the dishwasher for a while, such as when leaving for vacation, leave the door open while you are gone to ensure no trapped moisture leads to a mold or mildew problem.
I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
Delonghi magnifica promblems with water and milk
Frothing jug
For milk frothing issues, soak the milk jug cover in hot water and rinse several times. If it has a froth control that can be removed by sliding in the direction of travel towards the edge whilst jiggling it gently up and down. Clean off the little o-ring with a toothpick, be gentle. The control should easily slide and click back in place when done.
Froth still no good? Examine the milk coupling to ensure the o-rings are in the right spot and are pliable and undamaged. There should be an o-ring (usually green) on the top spigot, a (black) o-ring at the front of the bottom spigot and a (red) oring at the rear. The groove halfway along the spigot should be clear. Now with the toothpick and a hot moist cloth clean all the crud from the milk coupling, especially inside the smaller spigot. Check the tiny hole at the back of the larger spigot is not blocked.
Check the flow from the hot water spout is good. If not, there are internal issues, try descaling. If it is, test the frothing jug, if it is still weak either the jug cover or the milk coupling needs to be replaced. Get them to try a known good test jug at your local coffee service center to find out which, most will be happy to do this at the counter.
Jan 19, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Air conditioner
There is no filter, this smell is caused by mold/mildew in the system from normal condensation from the AC evaporator core, you can try Lysol, spray at the air intake in front of the windshield for about 20 seconds, turn of the system and let it set overnight, this will cure the problem for a few months, then you will have to treat it again, as the mold will regrow in the moist environment of the AC air distribution box.
Oct 04, 2008 | 2003 Buick Century
Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Oct 01, 2008 | Frigidaire FRT18B4A Top Freezer...
Mildew buildup on rubber at door opening
Hello mamie7,
You are not alone with your problem on your front load washing machine..seems they all suffer from this phenomenon. because in order to keep the water from leaking out the fornt door.. it has to be water tight.. and because it is water tight, it is also air tight so any water left in the gasket for any length of time will develop mold and get mildew there.. There are a few solutions ( no pun intended) floating around but I subscribe to a few basics.. One being .. wipe the gasket after a wash cycle and leave the door open to air dry any moisture that remains. The problem with this is that some housholds have small children and the washer then becomes a danger to them... So.. you can do a periodic wash cycle using a product called AFRESH ( in tablet form and sold at home depot etc) or you can try this product at http://www.smellywasher.com/ . Good luck.. hope this helps you..
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
True T-49 Side by Side Refrigerator Commercial Logo
143 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
