Question about Microwave Ovens
I just write in about my samsung microwave model ms7796w. I checked the door locks as you suggested for my key pad lock problem. It didn't work. However, I kept the door open and did the 0,2 start and it worked to get the help screen off. Them I went to punch in a number and now I've gotten myself to the demo w help flashing. What should I do now?
  • Microwave Ovens Master
  • 9,098 Answers
Refer to your owner's manual first of course.
Posted on Jan 17, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 28, 2007
SOURCE: samsung microwave oven (touch panel problem)
you can use the express button in touch pad,
Posted on Jan 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: control locked
If yours is a GE JVM1640 or similar GE model, here's what the owner's manual says:
To lock or unlock the
controls, press and hold
CLEAR/OFF for about
three seconds. When the
control panel is locked,
an “L” will be displayed
to the extreme right.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
Posted on Jul 01, 2008
Accidently locked microwave model#ME18H7045FS can't unlock HELP
try this. In future, the make helps :>) Also it is 'SF' not 5F. ME18H704SF
To Set:
Touch and hold the CANCEL/OFF Pad for
three seconds. The Display shows "LOCKED"
and the oven beeps.
To Cancel:
three seconds. "LOCKED" disappears from the
Display and the oven beeps.
Read more: http://forum.appliancepartspros.com/microwave-repair/441562-locked-microwave.html#ixzz4klZNPoYN
http://www.appliancepartspros.com
Here is your manual
Samsung ME18H704SF User Manual Setting The Time Child Lock Options Kitchen...
Here is the full details on you microwave from Samsung
OTR Microwave with Ceramic Interior ME18H704SF Owner Information Support...
Jun 22, 2017 | Microwave Ovens
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
Most of the buttons on my Goldstar MV1604SB stopped working
Does the display on your microwave read "Locked"? If so, then the Child Lock feature has been activated. To toggle the lock off, press and hold the Stop/Clear pad for more than 4 seconds. When this feature is active, most buttons are disabled to prevent accidental microwave use.
If holding the Stop/Clear button doesn't work, then I'd suggest there is a problem with the contacts behind the buttons. Sears Parts Direct has the parts diagrams for this microwave here: http://www.searspartsdirect.com/partsdirect/part-model/Goldstar-Parts/Microwave-Parts/Model-MV1604SB/1366/0123245 . (It's better to replace the control panel then to try to fix it.) Use the part numbers from the list to find price and availability at other sites.
The manual for the MV1604SB is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17638/GOLDSTAR-Countertop-Microwave-L0521424?brand_name_search=loosening+tight+screws .
I hope this helps.
Oct 13, 2011 | Microwave Ovens
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
My child locked the microwave pad. How do I unlock it?
The operation manual is available for free download from Samsung at this site: http://downloadcenter.samsung.com/content/UM/200305/20030529145700437_MW5592.pdf
The answer to how to lock and unlock is on page 15 of the manual. It's instructions are: 1. Press the '0' button, the display will show: "PRESS 1- DEMO 2-CHILD LOCK"
2. Press the "2" button, the display will show: "PRESS START"
3. Press the start button and the display will show "LOCK" then returns to the time of day.
At this point the microwave can't be used. To unlock, just repeat steps 1-3.
Hope this helps
Jun 18, 2011 | Samsung MW5592W Microwave Oven
My mother mistakenly locked her samsung microwave. She can't figure out how to unlock it and she can't tell me what model it is. Can you help?
On a friend's Samsung (she didn't tell me her model number either), you lock the keypad by pressing "0" and then "2". Press the same sequence to unlock the pad. Maybe this will work on her model.
May 31, 2011 | Samsung MW7490 Microwave Oven
Display says "Locked" and clock is on. Key pad wi...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, you may have a shorted membrane keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 19, 2010 | Jenn-Air JMC8130DD Microwave Oven
Microwave door locked
open the cover of the oven you can see see the lock near the key pad. Press the lock the door will open. You can adjust the alignment by refixinfg the screws.
May 12, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Magic chef micro key pad does not work
Try this site - It has answers to almost anything that can go wrong with a microwave, I know I read something there almost identical to the problem you mentioned:
http://www.repairfaq.org/sam/micfaq.htm.
Mar 24, 2009 | Magic Chef CMV1000B Microwave Oven
How to unlock the microwave
hi,
if there is a key on the pad that says "child lock" press and hold that for 30 seconds or so until it unlocks, if there is no key that says "child lock" try doing that to the "end/stop" key or the "start" key
Mar 30, 2008 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
