Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
C-11a2 C11A2 trouble isolation features
  • Konica Minolta Master
  • 6,161 Answers
Mite want to check inside the finisher. Did some recently grab a paper out of the finisher near the stapler. There is plastic bar could have broken off.
Posted on Dec 30, 2014
  • Konica Minolta Expert
  • 337 Answers
C11A2
Saddle exit roller
pressure/retraction
failure
• The saddle exit roller home position sensor (PS18) is not
turned ON even after the set period of time has elapsed after
the saddle exit open/close motor (M9) is energized (beginning
of pressure operation).
turned OFF even after the set period of time has elapsed after
of retraction operation).
Posted on Jan 30, 2013
Bizhub 554e error code C-4801
C4801
(1) Contents Trouble type Main unit board failure
Trouble code C4801 Rank C
Detection timing MFP detects simultaneous replacement of multiple boards.
Trouble isolation -
Relevant electrical parts • SSD board (SSDB)
• Printer control board (PRCB)
(2) Procedure
Step Action Control signal Location of electrical components
1 Reinstall the old PRCB. - -
2 If the above actions do not solve the problem, contact
KM. - -
NOTE
• Do not replace the printer control board and the SSD board at the same time. The backup data is lost and image failure may be
caused.
Dec 29, 2016 | Konica Minolta bizhub Office Equipment &...
Tip
Tricks for Keeping SQL Server Safely
Some simple ways to protect your SQL Server database
1. Using the Microsoft Baseline Security Analyzer (MBSA) to assess the server's security
MBSA is one of a variety of Microsoft products, which can scan unsafe configuration tools. It can be run locally; you can also run through the network.
2. Isolate your server and regularly back up
Physical and logical isolation would form the basis of SQL Server security. Database should be installed within the enterprise network security area, but not directly connected to the Internet. Back up all data regularly and store copies in a safe location outside the site.
3. Assign a strong SA password for a SA account
SA account should always have a strong password, even if Windows is configured to require authentication of the server. This will ensure that the server has been reconfigured in the future as Mixed Mode authentication; it will not appear blank or weak SA.
4. Restrict the permissions SQL Server service
SQL Server 2000 and SQL Server Agent is running as a Windows service. Each service must be associated with a Windows account, and derive from this account security context. SA log in SQL Server allows the user (sometimes including other users) to access the operating system features.
About reset SA password in SQL 2008/2005/2000
To secure our database we would like to choose create an intricate password. But even our selves would forget the SA password in SQL Server 2005/2008 sometimes. So here is a way for you to reset SQL Server 2005 password -- MS SQL Server Password Unlocker, which is a highly A Highly Technical and Safe SQL password 2005 Recovery tool. And following is a few features of the tool.
Features:
* Support SQL Server password recovery for MS SQL Server and MS SQL Server Express 2008/2005/2000
* No need to install MS SQL Server on your PC or lose data, the file master.mdf format is necessary
* Stop and resume MS SQL service automatically if the MS SQL Server on your PC is running
* Reset SQL password with ease no matter how long and complicated the SQL password is
* Easy to use
Feedback:
The most of people who encountered with SQL 2005 password losing problems are getting back to their SQL account now. We can also feel that ease and the hilarious mood when a hard nut has been cracked. Hope this MS SQL Server Password Unlocker would help more people and get their trouble erased.
on Nov 12, 2010 | Computers & Internet
Battery draining quickly on my ktm duke 690.What could be the cause
Setorwu, Youi will have to check for pararsitic draw of battery or make up a battery isolator. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KTM 690 SMR battery Isolator
How To Perform Parasitic Draw Test EricTheCarGuy
Testing Your Battery for Parasitic Load
Featured Article Looking for quick way to test parasitic draw
May 30, 2016 | KTM Motorcycles
Malfunction code c11a2
What model copier/printer sir/mam?
Apr 11, 2014 | Minolta Office Equipment & Supplies
My message indicator light does not blink when I have a voicemail on my Mitel SuperSet 4025. What do I do to make it blink when I have a mesage?
This is a feature code set by the voicemail system. If the code isn't set properly in the voicemail server, then the lamp won't light. Here's a few troubleshooting steps for you to follow...
Are others having the trouble? If so, then it's a system wide problem and you should contact your vendor to have it looked at.
If it is isolated to your phone... swap phones with another user with a 4025.... leave a message in your mailbox... did it light the lamp? If so, leave a message for the other user and see if it lights the lamp on your phone at their desk... did it light the lamp? If NOT, then you've got a bad phone and you should contact your vendor to have the set replaced/repaired.
sincerely,
Mark
Apr 29, 2011 | Mitel Superset 4025 Corded Phone...
My phone says parallel set on how i fix it
I assume you cannot get dial tone on your Vtech handsets or base unit. The phone is telling you that another phone or device has seized the line, therefore it cannot give you dialtone. You could have another phone or device(fax, modem, etc.) off hook or you could have trouble on the line caused by bad wiring, faulty line cord, or bad outlets. To find the trouble, you need to remove all devices from all outlets and try to isolate the bad wiring, line cord or outlet by connecting a standard good phone to one outlet at a time using a known good line cord. If you are unable to isolate the trouble using this method, try going to the outside interface box and testing the line there. Inside the outside interface box there is normally a test jack with a short line cord plugged into it, unplug the test jack and plug your standard phone into the test jack. If you don't get good dialtone then the trouble is with the service provider and you need to report it to your service provider. If you do get good dial tone then the trouble is in the building wiring, outlets or phone devices. Typically there is more than one pair of feed wires from the interface box to the building outlets. Remove all but one pair, then go inside and check all outlets for dialtone(plug standard phone into each outlet one at a time) to find which are connected to the pair of wires that are still connected at the interface box. If you find trouble on this feed wire( can't get dialtone at any of the outlets), remove it at the interface box and connect a different pair of feed wires, go inside and test all outlets again. If a feed wire tests good(you get dialtone on at least one outlet) then do not remove that feed wire at the interface box and just add the next one at the connection terminals in the interface box then retest your outlets again. Work your way through all of the feed wires and outlets in this manner to isolate where the trouble is. A bad wire, line cord, outlet or phone can produce a short or partial short across the telephone wire pair that will appear to your Vtech phone as if a parallel set is in use. It can sometimes take quite an effort to locate a bad wire or outlet. Good luck.
Feb 02, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
Service engine light comes on at 1/2 tank. Sometimes prompts me to tighten fuel cap. Have replaced with new OEM fuel cap.
Hello and welcome. this indicates a problem with the evap system, which a gas cap can be the problem, along with allot of more causes. could be a bad gas cap, vent sol. purge valve or one of the evap lines leaking. two things that need to be done to help find the problem. first thing, have the system scanned for trouble codes, the system will store trouble codes. this helps in isolating the problem. the second thing, is to have the fuel tank system smoke tested. this will will isolate the evap leak.
Oct 23, 2010 | 2004 Chevrolet TrailBlazer
Dome lights stay on after car is started
Check the rear hatch switches, My ford winstar did the same thing. I had ford fix it the 1st time, trouble came back, took panel apart myself, I found 2 switches 1 on each side of the hatch. I Isolated to one, and the other didn't do anything so I switched them around and trouble never came back.
Jul 28, 2009 | 2004 Dodge Durango
VW Jetta ESP issue
unless there is a ESP button (some cars have this feature, yours does not) no u can't turn it off. Have the system scanned by the dealer for trouble codes to help isolate the problem
May 29, 2009 | 2003 Volkswagen Jetta TDI
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
146 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
