Need user guide for nec powermate vl350 - Computers & Internet
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
You may download the user guide from here.
Posted on Jan 16, 2013
3 Suggested Answers
SOURCE: nec vl350 usb not working
Hi, First of all check that the usb is compatiable for your pc and the os.Check your installation and trouble shooting manual.
Or try connecting it to some other pc running vista.
check the device manager for the usb port and is active.
Install the device driver from cd if provided.Check the hardware for physical connections or any IO conflicts.Finally also try that usb is enabled in CMOS setup an make it to auto mode.
More troubleshooting tips if not solved, all the best
Anand.
Posted on Jun 11, 2008
joecoolvette
  • 5660 Answers
SOURCE: NEC Powermate V466 No power
billyto91, I haven't worked on an NEC Powermate V466 before, but searching the internet reveals it to be a desktop computer.
My sources do not exactly indicate whether it is a desktop unit, that the computer case resembles a 'pizza-box', or is a tower style of computer case.
This is a Service Manual I found online just now from NEC, (Free),
http://support.necam.com/mobilesolutions/hardware/Desktops/486/486man.ASP
Left-click on - Service and Reference Manual (ELSIE) for V466 Series (DT & MT)
(In blue)
This is a PDF file. May take up to 30 seconds before you see the first page. (Took 6 seconds to download for me, with a medium speed DSL connection)
The reason I posted this link, is to try to give you information on opening your computer case, and see what style of Power Supply it uses. More specifically, what main power cable the Power Supply uses.
1) Computer unplugged from power. Open the computer case. The Service Manual is less than, in that it has omitted some necessary illustrations.
Indication is, that there are two screws on the back of the computer case, that are removed. Then the cover is slid forward, and lifted off. ('Pizza-box' style)
BEFORE you reach inside, I advise observe anti-static precautions.
{Your body carries Static electricity. Static WILL fry out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, TOUCH the metal frame of the computer case.
This action will relieve your body of Static.
Should you get up, and walk away from working on your computer, upon your return Touch the metal frame again}
If you have a 20-pin ATX main power cable connector, or a 24-pin main power cable connector, there is a procedure that can be used, to see if the problem is the Power On switch, or the Power Supply.
Example of a 20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll down further for a 24-pin ATX main power cable, and it's connector.
I'm willing to bet you have a 20-pin ATX main power cable.
Observe the photo all the way to the right.
You will see a Green insulated wire, and a lot of Black insulated wires.
The Green wire is the Soft Power On wire.
ANY Black wire is a Ground wire.
The procedure is to use a jumper wire from the Soft Power On wire, to ANY Ground wire.
(It is a little more involved than this. Should you desire to do this procedure, state so in a Comment. {Believe upper right of your page}
I will detail in length of how to do the procedure)
IF, using the jumper wire turns the Power Supply on, the problem is a bad Power On switch.
IF, using the jumper wire does Not turn the Power Supply on, the problem is the Power Supply.
(Bad Power Supply. Weak Voltage power rail)
This is an example of a Power On switch, that I have found fit's many computers,
http://www.directron.com/atxswitch.html
I realize this is a bit much all at once, if one is not familiar with computer repair.
I will answer your questions to the best of my ability, and guide you step by step if needed.
Posted on Jun 08, 2010
Nec powermate vl350
You may download the manual from here.
Jan 15, 2013 | Computers & Internet
Hello, i've formated my pc a nec powermate ml6 2.8Ghz, and I'm looking for a sound driver for this computer. can you help me
http://www.nec-computers-ap.com/user/Default.aspx
Hi, try the above NEC support page, select your model and then download drivers you need.
If this helps please rate me
May 13, 2011 | Computers & Internet
NEC Desktop POWERMATE ML6 ML7 R series PCI
What is the actual device? Nic, Audio Video etc?
Nov 04, 2009 | NEC PowerMate ML4 PC Desktop
Hard crash, Need To Replace BIOS
If you're not good at sodering I'd suggest replacing the whole motherboard. Otherwise go Here <<< for a guide on the bios, and how to replace it.
Apr 27, 2009 | NEC PowerMate eco PC Desktop
NEC Versa Notebook S Series User Guide
Here you go.
NEC Versa VX User Guide
Don't forget to rate my solution FixYa
Thanks!
Mar 01, 2009 | NEC Versa VX Notebook
Need driver Motherboard
i need n4-ibfgl motherboard driver for
ethernet controller
audio driver
vedio driver
please help me.....
Apr 23, 2007 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
