Question about Sunbeam Cafe EM6910
Sunbeam em6190 wont pump water - Sunbeam Cafe EM6910
My spa pool is coming up with FLO flashing where the temp is shown, its a sunbeam and now wont hold temp
when a spa shows flo in a alarm message (like yours) this is a indication that the flow sensor is telling you that it has not enough flow thru the filters this most times disables the heater so it wont become overheated , Most times its caused by dirty filters or a foreign object getting past them , but ive also seen very poor water chemistry cause a false showing of this message , this usually requires a sensor replacement and correction of water chem to correct this
Aug 30, 2015 | Pool & Spa
Leaking water under the drip tray
First, be sure to regularly push a straightened paper clip in that nozzle! It can get clogged with coffee grinds quite easily.
Then call Sunbeam and tell them you want the waste chute extender. It's a little plastic tube that fits over the nozzle to extend it further into the drip tray. Truth be told, you could probable push a 2cm piece of 3mm aquarium pump air tubing over it.
May 22, 2013 | Sunbeam Coffee Makers & Espresso Machines
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
Sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Mar 26, 2009 | Avanti Hot and Cold Water Cooler
I have a sunbeam water cooler and it leaks can u help me..
Hello dneary55
You said, You have a sunbeam water cooler and it leaks can u help me..
Where is it leaking from?
What is the model number and how old is the water cooler ?
If you are under warranty ( Which is 1 year parts and labor
Below you can find an authorized Sunbeam service center.
http://www.sunbeam.com/servicelocator.aspx?section=kitchen
If not you may want to use a sponsored service center here at fixya.
Waiting to hear back form you
Huuum
Sep 30, 2008 | Sunbeam Refrigerators
Sunbeam water cooler SA12587 - no hot water
I have a Sunbeam water coooler YLR2-5 87H
My water cooler is not cooling at all. What should I do?
Nate 901-754-0028 or nstclair1@aol.com
May 11, 2008 | Refrigerators
Sunbeam Cafe EM6910 Logo
79 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
