Question about Hotpoint RVM1435 Microwave Oven
Fan making a noise
Fan seems to hitting something.....then it goes away
  • Hotpoint Master
  • 9,047 Answers
I would bet that the blade is loose on the shaft.
Sometimes glue can fix that.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 17, 2013
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
Makes buzzing noise
MAY BE ANY OF TRANSFORMER MAY BE DEFECT OR SCREWS ARE LOOSE
Jan 09, 2014 | Microwave Ovens
My jvm149osh01 is making noise even when not in use
does this unit have a turntable and its ti turning?? Bad door switches??!!
Jul 27, 2017 | Microwave Ovens
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
HOW TO REPAIR MAYTAG MMV4205AAW MICROWAVE NOISY FAN
unplug and take apart and more than likely something is hitting the blade or it has slid down the shaft and is hitting the motor or the cover if u pull the blade off and plug in and it dont make the noise then the blade is hitting something if the motor is still making a noise then the motor needs replacing
Jan 11, 2010 | Maytag Appliances Over-the-Range Microwave...
Making noise like fan is hitting something
Open the ducting above the microwave and look for leaves or anything else in the fans way.
Dec 26, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Whirlpool otr microwave
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Apr 18, 2009 | Microwave Ovens
Funny Noise coming from my microwave
Some of the soup got into the fan. You can continue to use it and hope the noise goes away on its own or you can have a techie clean it.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave with vent fan
hi possible magnetron problem but also check highvoltage capacitor and diode . the process of ellumination is the only way to help u .first disconnect connegtor to magnetron and switch oven on if noise goes away eureka repeat with other components
Mar 18, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
20 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Jerry Greenberg
Jerry Greenberg
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
