Question about Belkin (F6D42304) Wireless Router
How to switch off wireless mode on belkin router F6D4230
I want to use it only wired.
  • vladan_mitro
    vladan_mitro Jan 16, 2013
    In the Channel and SSId menu, Protected Mode was already set to off, but the wireless is on, connecting with my laptop. Any other idea?
  • 826 Answers
Log into your router's webpage, go to the Wireless > Channel and SSID menu, and set the Protected Mode to "Off".
**If you need any kind of technical assistance you can contact support cell at
Posted on Jan 16, 2013
  • 2263 Answers
SOURCE: belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
Posted on Jan 14, 2010
  • 2263 Answers
SOURCE: Can't find my WPA 2 code to use on the Xbox with
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on Mar 23, 2010
SOURCE: I have a Belkin F6D4230-v1 router which will not
please can you tell me my security key as my laptop cashed
Posted on Aug 21, 2010
  • 7733 Answers
SOURCE: The wireless light is orange and blinking on a
Go to Belkin Support --->BS.
Posted on Oct 05, 2010
  • 266 Answers
SOURCE: I have a belkin enhanced wireless router model #
Troubleshooting Internet disconnects
Are all computers connected to the router affected?
If so, try this first:
  1. Unplug the power to the cable / DSL modem
  2. Connect the power to the router.
  3. Connect a computer to one of the LAN ports of the router.
  4. Restart your computer.
  5. Restore the router to factory defaults. Note: This will remove all previously configured settings.
  6. Once the router has gone through the restore it will then begin the reboot. When the reboot completes plug the power back into your modem.
This addresses a common scenario where the router has been connected to the Internet for an extended period and holds an IP address (DHCP lease) for a longer period of time than your Internet Service Provider (ISP) allows.
This is normal and does not indicate any issue with your Belkin router or ISP.
If the router is located where you cannot easily unplug it, you can restart it using the router's web-based interface. If your DHCP lease time seems to be extremely short, contact your ISP to see if there are other issues on the network.
In certain network scenarios, it may be helpful to turn off all the equipment on your network, and then turn it all back on. Leaving some devices unplugged for up to five minutes can also help. Try unplugging the router, any switches, and any cable or DSL modems. Shut down connected computers. Plug in the cable or DSL modem first.
Plug in the Belkin router second, and wait for the lights to cycle through the startup routine. This prevents another device from taking the DHCP lease. Lastly, start up your computer.
Are just wireless clients affected?
If so, focus on factors that affect wireless clients, such as:
  • Network selection and security
  • Hardware access control
  • Client TCP/IP settings
  • Signal strength
  • Sources of interference
Are just wired clients affected?
If so, check your network adapter settings. Check all cable routing, connections, and power supplies.
Can you connect to the Internet directly?
Set up a computer to connect to the Internet directly, without the router.
If you cannot connect to the Internet without the router, please contact your Internet Service Provider for assistance.
Check your signal strength
You may lose your wireless connection if you go beyond the range of the router, or if there is an obstacle between your computer and the router that blocks wireless signals. You can check signal strength by opening your wireless adapter's interface.
Is your modem configured correctly?
For Windows XP and 2000:
1. Connect your computer to your modem with an Ethernet cable.
2. Click Start, and go to Run.
3. In the Run box, type CMD and click OK.
4. In the DOS window that opens up, type ipconfig and then press Enter on your keyboard.
For Windows Vista/7:
1. Connect your computer to the modem with an Ethernet cable.
2. Click the Start button and in the Start Search box, type cmd. You can either press Enter on your keyboard or click on cmd.exe when it appears in your search list.
3. In the DOS window that opens up, type ipconfig and then press Enter on your keyboard.
4. The IP address (or IPv4) will be a series of numbers following the pattern (for example,
After following either of the steps above, your IP address is, then your modem is also a router and will need to be bridged by your ISP. If your IP address begins with a 169.254, your computer did not receive an IP address from your ISP.
Posted on Jan 19, 2011
I want to take the security lock off my belkin f6d4230
Hi here is the answer for your question:
1. We need to establish a direct connection bit-win your router and your pc or laptop using the UTP cable one side of the cable must need to connected to one of the port in the back side of your router the other side to your lan port.
2. open explorer or any browser you using and type on the top search bar this is the address of your router press enter and you will contact your router set up page.
3. after you must go to wireless security that appera in the left side of the page, after that you will able to change the password of your wireless security.
more question let me know
Nov 17, 2012 | Belkin Basic Wireless Router
I have had to unplug my computer for several months. my berkin router is now not working modle enhanced wireless router f6d4230-4v1 i have losted my cd starter disc, and can not find the instuctions for...
Instructions/User Manual for Belkin Wireless Router F6D4230-4can be download from this link. It has all the instruction for setting-up and configuring the router.
Good Luck!
Hope this helps!
Dec 31, 2010 | Belkin Computers & Internet
Install router N150 Model F6D4230-4V1
click here to configure your router according to your ISP...
Aug 04, 2010 | Belkin Computers & Internet
What does it mean when just the wireless light is out on the router? We have a desktop the router is based at, a laptop with wireless. It has been working fine until now. The laptop cannot find a network...
The light on the router should be there. If you do not see any light there, this refers to Faulty Router. Try to play with the wires and see if that could help the situation.
Also, try to wires. They should not be uncut or burnt one.
Reset - On few Models, you would see a switch on the back. Try to OFF and ON the switch again.
There should be a Hole on the back of the router. Take a Pen or Something of that sort and press the pin in the hole and check if that could fix the problem.
If still, the light do not turn ON, you need to get it replaced.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 23, 2009 | Belkin (F5D5231V4-SN-PD) Router...
Belkin (F6D42304) Wireless Router Logo
66 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
