Question about Kenmore 44072 Front Load Washer
Door opens on the wrong side
Dan I reverse the door on a 417 model Kenmore frontload washer?
  • 130 Answers
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Posted on Jan 24, 2009
How is the doors reversed on ffp187b
Reversing your washer door - YouTube
? 5:14
www.youtube.com/watch?v=abpAu_5Uhfc
Feb 16, 2011 - Uploaded by Kenmore You can switch the side the door on our new dryers (model #s starting with 417) swings on. This video will tell ...
Jul 30, 2015 | Washing Machines
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
I just replaced one of the suspension springs in our Kenmore 417 frontload washer. When I turned the washer back on and tried to run a load, it will run for about 5 seconds then stop for about a minute...
can you give me some explanation on what you did to replace the spring?. did you have to take the washer apart?. check the wire. maybe you forgot or did not plug all the way a connector. or came apart. my impression is that something came loose and the computer is not detecting a connection.
Feb 09, 2011 | Kenmore 44042 Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
KENMORE FRONTLOAD WASHER Model# 41741052000
very common for the tub seal to leak - or bellow to be ripped.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Kenmore 44102 Front Load Washer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
My kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Nov 16, 2008 | Kenmore 44102 Front Load Washer
HOW DO YOU TAKE THE DRYER OFF?
If it is stack from the factory (ie..came as one peice) you cant
Jul 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 44072 Front Load Washer Logo
118 people viewed this question
Sal De
fordexpert
Robert Rankin
