Question about Timex Hardware & Accessories
Gem 24 Hour Lighting Timer doesn't work Model # 0606
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
SOURCE: general electric 24 hour timer ge5101n can it be
ge5101 can be used with cfl
The timer turns the circuit on-and-off like a light switch.
Anything a light switch can turn on, a timer can turn on.
Posted on Oct 09, 2010
SOURCE: I need instructions for how
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Posted on Oct 26, 2010
heatman101
  • 43501 Answers
SOURCE: BRINKS MODEL 42-1020 A 24-HOUR TIMER WITH 15-
Not sure what your problem is exactly....is it not working? You don't know how to set it???
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Posted on Nov 27, 2010
Intermatic dial doesn't automatically switch sprinklers
1) Trippers can wear down. Transformer can go bad if model has 24Volt output. Relay can go bad.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
2) Add a comment Feb 2013 with model number, and include if this is new timer or older timer that worked before and stopped working.
Feb 10, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
Model dehumidifier DDR2611/4011, how do you set the timer? What is the on and off timer for, and the 24 hours?
Boy you know you're in trouble when a web search for your product gives fixya on page 1 google.
There is a product manual for your dehumidifier Sept 2012: but it doesn't say how to set the timer. What a doofus manual.
http://www.danby.com/cms/products/en_manual/Manual_for_DDR26114011_%282%29.pdf
There is a customer care phone number:
http://www.danby.com/en/CA/customer_service
On and OFF are probably manual override, so you can operate unit without timer.
24 hour means a 24-hour military-time clock without am and pm. So 1pm is hour 13, and 8pm is hour 20, and 1am is hour 1, etc.
+/- set the humidity
Best guess for Seting the timer.
Press and release clock (timer) button. You may have to press and hold.
And probably auto start is first thing on menu.
Press + or - button to select start hour from 1 thru 24.
Press clock (timer) button again.
And probably auto stop is next.
Press + or - buttons to select stop hour from 1 thru 24.
Probably you press clock button again to exit timer programming.
Sep 06, 2012 | Hardware & Accessories
Clock does not rotate
If clock does not rotate, then check if outlet has power. Check for loose wires.
If clock rotated before and stopped working, then clock motor might have gone bad.
Replacement clock: Taco timer uses the FM1 timer module.
Voltage and timer information appear on back of timer.
Open following links to identify timer and model number:
http://waterheatertimer.org/images/FM1-5-image.gif
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/modular%20din%20rail%20timers/fm1%20series%20-%2024%20hour%20and%207%20day.aspx
For example Taco timer module is 24 hour, and 120Volts, and doesn't have battery back-up.
-If timer has on-off-timer switch, then model number is FM1STUZH-120U
-If timer does not have on-off-timer switch, then model number is FM1STUZ-120U
More resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
Sep 17, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Jun 25, 2011 | LG LHD45EL Dehumidifier
I just bought this timer and do not understand how to find pins. III Woods Model 59204EV
Here's the 1-page "manual" fo ryour timer:
https://www.ccixpress.com/wcsstore/CCIxpress/images/catalog/catalogPDFs/Part%20No/59204.pdf
As an electrician, I rarely have to dal with these plug-in timers, since when they fail, consumers
will just discard them and buy another, but as a timer owner, I can try to describe the "pins" and
operation of your Woods 59204ev timer.
1. rotate clockwise the center dial to inform the timer what time it is now.
you'll want to rarte the dial until the time on the dial points to the ARROW.
The dial is marked in either a 12-hour or 24-hour format.
2. the "pins" are on the outer edge of the dial - tilt the pins OUTWARD during the time(s) on the
timer's dial that you want your timed devce (10 Amp max lighting, 15 Amp max resistive (heater))
to be on, and tilt these pins inward for the times/hours that you want the same device to be off."
Thes pins are advertized to be "Never-Lose" pins, since unlike many past model timers, the
on/off pins for your Woods 59204EV timer are not removable. Consumers would consistently
lose or break the small plastic removable pins of yesteryear, rendering a fully functional timer useless.
May 16, 2011 | Hardware & Accessories
I am having trouble running an american dj quad gem in dmx mode. I have other lights that are working fine.
If by chance teh light is on the end of a long DMX cable run, read about putting a terminating resistor at the end of the chain. You say you are having "trouble"... that doesn't tell us anything that we could help you with.
Apr 23, 2011 | American DJ Supply American Dj Quad Gem...
General electric 24 hour timer ge5101n can it be used uith cfl (compact Floricent Lighting)
Oct 08, 2010 | Solar Ge 24 Hour Timer 2 Pk (ge24t)
How do you set a older outdoor noma light timer only 2 buttons
Hi.
See the instructions below in PDF format, instructions are for Noma two buttons heavy duty outdoor timer. Some model may be different in shape:
24-Hour Heavy Duty Outdoor Timer
Regards.
Ginko.
Jul 21, 2010 | Home
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Hardware & Accessories Logo
122 people viewed this question
Top Timex Hardware & Accessories Experts
ray gallant
Gene Haynes
Are you a Timex Hardware and Accessory Expert? Answer questions, earn points and help others
