Question about Coffee Makers & Espresso Machines
How to adjust drop - Coffee Makers & Espresso Machines
    Problem Solver:
  • 5 Answers
What are you trying to do? What do you want to adjust?
Posted on Jan 16, 2013
The cutting height adjustor pedal drops to low cut setting? Why?
the adjustment rod screws into a threaded receiver raise the tractor and screw the threaded screw back in then make the adjustment. Good luck
Feb 11, 2016 | Husqvarna Garden
How do you know that the Classic Drop Spreader is adjusted properly? i'm using too much fertilizer in comparison to my old Scotts drop spreader and leaving too many burn marks. I thought that the...
I'm sorry to hear about the problems you are experiencing with your spreader. You're right, this is the correct way to adjust the calibration of the Classic Drop Spreader. If you are still having problems, you can call Scotts at 877-465-5160, and we can assist you further.
Hilary @ Scotts
Aug 21, 2011 | Scotts Company Scotts Turf Builder Classic...
Chain dropping when freewheeling
Bike chain is loose. Adjust the tension by moving the rear wheel backwards by loosening the axle nuts & again tightening it. Try freewheeling while adjusting so as to not drop the chain.
sonsunny
Jul 09, 2011 | Cycling
Hello, my Briggs & Stratton generator, PP5000, Intec, 8 hp, Model 202412, type 0167E1, has lower power output, 180 Volts in stead of 220-230 Volts. Any idea where I should look ? Engine is 8 years...
Hi and welcome to FixYa. I am Kelly
Usually when you have a lower voltage output that is yet above 150 VAC the problem is as simple as the engine is no longer running at full speed. This could be caused by binding carb or governor linkages but more often than not the Governor adjustment screw has backed off over time causing the engine to gradually slow so the output voltage drops. The user does not notice it so much until the output drops more than 15% and you notice dim lights... slower running equipment etc.
Look for a circular plate / governor speed plate near the base of the governor lever but off to one side that has a spring that attaches to the governor lower end of the governor. There should be a screw with a locking nut. Loosen the nut and turn the adjusting screw clockwise to increase engine speed. (You may have to barely loosen the pivot nut on the governor speed control adjustment plate to make the speed adjustment.... tighten when done with speed adjusment) Watch your output voltage and adjust the voltage to 225 VAC with NO LOAD. The voltage will drop as loads are added. Make sure to tighten the lock nut on the adjusting screw or in a matter of an hour you will have low voltage again from engine speed dropping. What ever you do.... DO NOT adjust the governor arm base attach point where it attaches to the engine.
Just so you know a weakened governor spring can cause the speed drop also. If the speed keeps dropping with extended use, you may have to change the spring that goes from the lower end of the governor arm to the governor speed adjustment plate.
Thanks for choosing FixYa,
Kelly
Apr 20, 2011 | Briggs & Stratton 3,250 Watt 6.5 Hp...
How do I adjust the rear suspension to accomadate rider and luggage?
Load the bike and sit on it. Now bounce up and down. You want the front and back of the bike to drop together. If the front drops first on a hard corner and you hit a slippery spot the front of the bike might wash out. If the back drops first in the same situation, the back might skid out , a little easier to recover from, but still dangerous.If you are able to adjust both front and rear, you should be able to set up a perfect soft ride or firm ride. If you can only adjust the rear, than you want to adjust the drop in the back to match the fork drop. This is how the racers set up there sport bikes for hard cornering , but it works for all styles of riding.
Jul 30, 2010 | 2005 Suzuki Boulevard C50
FIM70 Makes ice but does not drop. Forms large block of ice over cups.
don't know if you solved this, but we had a similar situation.
Leave the machine off until all the ice melts off the cups.
You need to take off the front cover and adjust the sizing down a good quarter turn. Let it start making ice and make sure all the ice drops. If it doesn't size it down more. If it all drops and the ice is too thin, turn it up VERY little (2° or so). Keep adjusting until you get the size you want but still get all the ice to drop.
Jun 30, 2010 | Franklin Industries Franklin Chef FIM200...
I have a new Puma La5721 and when I adjust the pressure to 120, it drops back to 90 and starts running aagain,after releasing pressure from below the switch box. Am I doing something wrong.
yes buddy it will do your adjusting the stop pressure so say you set it too 150psi once it reaches this pressure it will stop then as the pressure drops to about 120psi the compressore will restart and build to 150 again and you can adjust the starting pressure
Oct 11, 2009 | Air Tools & Compressors
Lowering 1990 toyota pickup
drop blocks in the rear, and I recommend drop spindles in the front, and new shocks. You may also drop the front through torsion bar adjustment. The bad thing with torsion bar adjustment is very harsh ride. Hopefully this helps
Aug 17, 2009 | 1990 Toyota Pickup
Cruise control drops out
Break switch maybe to sensitive or out of adjustment causing cruise control to drop out while going over bumps. Check adjustment on the brake switch. There is also a switch on the accelerator linkage as well.
Jul 28, 2009 | 1994 Ford Aerostar Extended
Ec12 hard restart after drop in air pressure
It sounds like the air pressure assembly unit is not reading the pressure drop. some of these units have adjustments under the covers and be reset.
Aug 31, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Coffee Makers & Espresso Machines Logo
20 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
