Question about Kenmore 15864/15862 Top Load Washer
Need help replacing lid switch. can it be done on the kenmore 90 series with out removing the top casing?
  • 130 Answers
It can but you are making more work than you need, take it apart and do it the right way. remove the cabinet and go from there. trust me I have tried and will never do it again.
Posted on Jan 24, 2009
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
I have Kenmore 90 series washer its lid switch is not working I want to replace my self how I can fix it model # 110 20922991
remove the top control panel,there are 2 brass colored clips that hold the cabinet on,remove these clips and tilt the cabinet forward to remove it,then you can replace the lid switch
Oct 14, 2010 | Kenmore Washing Machines
I have a Kenmore 90 series washer top load and I need to replace the lid switch. Can you tell me how i get the top of the washing machine off or take the chasis apart. Thanks.
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 02, 2009 | Washing Machines
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 90 washing machine will not spin or drain
I hate to say it, but your friend is probably wrong on this one. A bad pump would not affect a washer's ability to spin. It would only affect the drain function. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at,,, Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, please let me know. I hope this helps you.
Aug 01, 2009 | Washing Machines
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave
Dec 17, 2008 | Kenmore 23822 Top Load Washer
My washing machine water wont drain,it is a kenmore 90 series.
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Jul 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
79 people viewed this question
Sal De
 Brian Main
Brian Main
