Question about Microwave Ovens
I ran my micro oven for 60 mins. empty. what happens to oven.
I turn the oven on before I put food in for about 60 mins. It doesn't seen as powerful now.
  • Microwave Ovens Master
  • 9,047 Answers
When that happens, the magnetron overheats, which can damage or destroy it.
Only a new magnetron can fix this.
Posted on Jan 17, 2013
SOURCE: I have a GE Profile Model #JE1860SB001 serial
I have a GE profile Model # JE1860SB001 that comes on but will not heat.
Posted on Apr 26, 2010
heatman101
  • 43501 Answers
SOURCE: I foolishly ran the oven empty for 2 mins. I heard
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 11, 2010
shbarker
SOURCE: PANASONIC - SENSOR 1200 W. microwave
All electronics work but microwave won't heat.
Posted on Sep 21, 2010
heatman101
  • 43501 Answers
SOURCE: How to fix an Emerson microwave 8992RD that
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on May 08, 2011
  • 6771 Answers
SOURCE: My GE Microwave Oven won't
There is a solid state switching device called a triac "electronic voltage controller" that has malfunctioned, it controls the power level settings when making power selection, It will need to be replaced to correct the problem. This repair should be done by a qualified technician because dangerous high voltages are present.
Posted on Jun 07, 2011
AEG micro-combi oven has big condensation problems. The glass on the oven door clouds over and drips of water can be seen on the glass. Water also drips out on both sides of the oven at times formin
Condensation inside the oven comes mainly when the temperature is below 100 Celsius, and this phenomenon is evident in almost all manufacturers. That means, the condensation starts at the beginning and at end of baking. My advice is the same as many manufacturers recommend: Before baking, preheat the oven to min. 100 Celsius and after that place the food in the oven. Reverse the procedure in the "cool down" phase before the temperature drops below 100 ° C and remove the food from the oven.
After that condensation should be drastically reduced.
Condensation could be technically solved but it would be too expensive for manufacturers (more parts inside oven) as well as for customers also (too expensive appliance and lost energy).
Dado
PS. This applies to the traditional way of baking
Feb 14, 2015 | AEG Microwave Ovens
Why can't you run a microwave without anything in it? What happens and can you fix the problem? I forgot to put the food in and ran it for 4 minutes with nothing inside. Now it won't heat any food.
A microwave oven works on the principal of a high power high frequency radio transmitter. The device that emits the microwave energy is a tube called a magnetron . When you run the microwave empty with nothing to absorb the microwave energy it is all reflected back to the magnetron causing it to overheat and destroy itself or cause failure in the High Voltage power supply due to excessive current draw.This is caused by standing waves.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
I'm experiencing the same exact problem as theresagolde experienced. PROBLEM:Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work...
You can modify a standard, typical micro switch available at many places or, you can get an exact replacement from GE parts placed or you can try www.repairclinic.com or you can try a FixYa.com advertiser.
You are correct in trying the safety interlock switches ... they cannot stand the opening and closing of the door while the machine is running. To improve the live cycle of these tiny switches is NEVER open the door while the oven is operating.
Thanks for your question @ FixYa.com
Jul 28, 2011 | GE JVM1330BW/WW Microwave Oven
How to fix an Emerson microwave 8992RD that carousel doesn't turn and doesn't heat your food..
heatman101
May 08, 2011 | Emerson Black Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
