Question about Frigidaire FPHD2491KF Dishwasher
Are lights supposed to be on when the dishwasher is running and the door is closed?
The dishwasher has no lights on the panel when the dishwasher is running. When the door is opened, they all function correctly. I can start and cancel when the door is open, but none of the buttons do anything when the door is closed. I am unsure if this is expected operation or if it is malfunctioning.
The buttons and the display panel are not lit when the machine is running. This is to save energy according to frigidaire. I wish I had know this before purchasing it about a year and a half ago. The cycle count down timer was a big reason I purchased this one, but what good is it if it only works when the door is open?
Posted on May 15, 2013
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
woobie dog
  • 1273 Answers
SOURCE: My dishwasher, model # fdb1050reb1, will not start
You may have already, but try opening and closing the door and restarting the machine again. If the door switch is loose, you may be able to get it to make the connection and run. If it just palain won't work that way for you, you'll have to try to tighten up the connections on the switch, or replace it.
Best regards, --W/D--
Posted on Aug 03, 2009
  • 415 Answers
SOURCE: dishwasher won't start. Control panel lights come
under the plastic door liner is the pcb timer and the white looking with 2 wires hooked to it needs replaced always unplug or shut off power to unit if working on it if you know how to use an ohm meter take a resistance reading if none replace the thermal fuse....
Posted on Aug 19, 2009
  • 901 Answers
SOURCE: my dishwasher wont run
Check the water level switch/ pressure switch.
Control panel may not have full control. There may be yet another
board inside!
Posted on Sep 15, 2010
SOURCE: My frigidaire dishwahser was set to run a normal
DId you get a solution for this? Mine is doing the same thing...
Posted on Dec 20, 2010
Kitchen aide dishwasher won't start. Water left in bottom after last cycle. No lights will come on along the panel. KUDI01FL
I had this and the thermal fuse needed to be replaced ($14 part).
If the lights won't come on on the controller and you are sure you have power to the dishwasher, then check the thermal fuse.
1. turn off the power to the machine
2. open the door and unscrew all the screws along the inner edge
3. gently split apart the layers of the door and access the controller; it is inside the door and just below the buttons that are supposed to light up.
4. the thermal fuse is white and clipped onto the side of the control box close to the top of the door.
5. unplug the leads going into it and check it with a multimeter - if no current goes through it then it needs to be replaced
relatively easy fix - good luck!
Aug 07, 2010 | KitchenAid 24 in. KUDI01FL - Multiple...
Hi, Should I press Start button first or close the door first and then push the start button? If I do the later, I can't see the control panel, although my dishwasher has been installed 1/2" lower than my...
If you are referring to the style dishwasher that has the controls on the TOP edge of the door, you are supposed to select the preferred cycle and options you wish to use, then press START while the door is OPEN. You will then have about 3 seconds to close the door. If you fail to shut the door in the allotted time, the program will cancel and you will have to repeat the steps. This information should be printed in the owner's manual under the operating instructions.
Jul 01, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
I opened the door at the beginning of the cycle to move something and then the dishwasher wouldn't start again.It still won't start and we can't get the water to drain either.
If the dishwasher was working fine before you opened it to move something, and now it does absolutely nothing, then I would suppose it is a door switch issue. The door switch is located at the top middle of control panel, and is there are a safety device to keep dishwasher from running with door opened. You need to play around with closing the door and pushing the top in various ways to see if you can get it started. However it is more than likely a faulty switch.
Mar 10, 2010 | Whirlpool 24 in. DU920QWD Built-in...
Dishwasher was opened to add dish and would not start back
give it a few minutes it may have a built in delay when cycle is interuptede
Jun 01, 2009 | Dishwashers
My Kitchenaid dishwasher won't start.
sounds as if your having a problem with the latch assemblt, not recognizing the door is being closed, so its waiting fot he door switch to be activated
Jan 10, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Feb 28, 2008 | Dishwashers
Frigidaire FPHD2491KF Dishwasher Logo
121 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
