Question about Motorola 53727 Earbud with Push-To-Talk Microphone
I want to use my Motorola Talkabout and iPod through the same earbud, is there an adapter of some kind?
I'm listening for radio traffic, but it's mostly quiet, so I'd like to listen to music too through the same earbud. Is there a Stereo-to-Mono adapter I can clip into the base of the earbuds, like a reverse splitter? I don't want a switch, the radio can talk over the music or drop it before talking, either way is fine. Everything has to fit in my pocket since I'm not usually carrying a bag and can't have stuff on my belt.
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Dimitri,
Q. Does your Motorola have an ext speaker outlet, if so, then going the a radioshack or similar store would be an avenue, make sure you take your Motorola with you so they can give you the right adapter.
If this is successful, I believe we've solved the problem.
I hope that this solves the problem for you.
Kind regards,
Peter
Posted on Mar 05, 2013
Benimur
  • 6966 Answers
SOURCE: Push to talk problem
If indeed radio #1 has a mic problem, this may be confirmed by trying an external speaker/microphone plugged into the accessory jack. If still a no, then its not the mic but possibly the modulator circuitry. If there is transmit audio with the external mic and hence internal mic is defective, the unit would have to be pried open and the defective component replaced. The internal mic is normally an electrofet 2-3 terminal soldered to a shielded wire and physically attached to the front plate.
Alternately, another possibility is that radio #2 has its Interference Eliminator Code enabled/activated. This is indicated by the presence of small sized digits on the top right of display. If this is the case and no similar digits are displayed in radio #1, then radio #2 will not allow any received transmission to be heard. Along the same line of reasoning, if the code is activated on both radios signified by the presence of the 2 small digits, and radio #1 has a problem with its CTCSS (code) generator, then it would also prevent reception of radio #2. A way to verify this is by deactivating/disabling the Interference Eliminator Codes on both radios.
On certain occasion, it is also possible that radio #2 has a defective speaker. You should be able to verify this by plugging in an external speaker to the accessory jack of radio #2.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 10, 2007
  • 6 Answers
SOURCE: Motorola talkabout t 6530
I just spoke with Motorola and they advised output for that particular charging base is 9 Volts 200 Ma output hope this helps, good luck!:)
Posted on Dec 17, 2007
Neto
  • 123 Answers
SOURCE: Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
Posted on Dec 12, 2006
eradiostore
  • 1654 Answers
SOURCE: MOTOROLA TALKABOUT TWO WAY RADIOS WONT TRANSMITT- BOTH CAOME ON
Here is the manual for the T5720. It may be very similar to the model you have.
http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Posted on Nov 20, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola Talkabout T8510TPR frequencies
Here is a copy of the user guide http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
The frequencies are listed in a chart on page 2.
Best regards.
Posted on May 26, 2010
Testimonial: "Very helpful! Thanks :)"
Need AC adapter Motorola Talkabout T5720
Hi Tom,
Take your radio to your nearest Radioshack or similar store and I'm sure the team there will be able to help you with an adapter (charger?)
Cheers,
Peter
Oct 07, 2012 | Motorola Talkabout T5720 (7 Channels)...
Will motorola t6500's or t5300's work with cp100's?
No, the TalkAbout family radio service/GMRS radios and the CP100 business radio have no frequencies in common. Sorry.
best regards.
Jul 12, 2012 | Motorola Talkabout T6500 (7 Channels)...
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
T5900manual
Here's an online copy on Motorola TalkAbout T5900 2-Way Radio user's manual:
http://www.motorola.com/mdirect/manuals/T59xx_User_Manual_E.pdf
Jun 27, 2011 | Motorola TalkAbout T5900 (14 Channels)...
Issues with Motorola TalkAbout T5900 (14 Channels) 2-Way Radio. Do they need FCC programing & licensing to operate? Because I can not get the to communicate with each other!
Yes they do.The thing about the talkabout is that they work according to the network area they are connected to and the number of the talkabout they are also connected to.So all you need do now is to take the talkabout to motorola shop so that they can confrigure it for you.
Jan 22, 2011 | Motorola TalkAbout T5900 (14 Channels)...
Where can I buy repair parts for my Motorola T5720 Talkabout radio?
So sorry, parts have never been available for the TalkAbout line of radios (other than TalkAbout Distance & DPS). If you are looking to repair an existing T5720 unit, your best option would be to locate a like-model for parts. eBay can be a good source.
As for replacement batteries and accessories you can use the Motorola TalkAbout Accessory Store.
Best regards.
Mar 20, 2010 | Motorola Talkabout T5720 (7 Channels)...
Motorola 53727 Earbud with Push-To-Talk Microphone Logo
66 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
