Question about HP Pavilion Computers & Internet
Sound probablems have a laptop computer and the sound quit working
  • HP Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Posted on Jan 16, 2013
My Altec Lansing AVS 300 external computer speakers quit working on my laptop. They work fine on another laptop. Please suggest a solution to get these speakers to work on my computer.
Check if the sound card is correctly setup with drivers.
Do this by going to Control Panel, Device Manager and check on sound cards.
Can you hear sounds from regular laptop speakers??
If not, the problem is in the sound card, which is already integrated on the motherboard.
This makes it harder to fix, unless your laptop is under warranty.
If it is software related to the OS or conflict with other devices, you are more likely to fix it.
God Bless You!
Feb 05, 2011 | Altec Lansing AVS 300 Computer Speakers
I upgraded my os to xp pro sp2 however drivers no longer work after the upgrade
thats a common probablem if you are upgrading your os.. because some drivers are not compatible to your os so you need to update the drivers by going to the manufacturers website of your hardware.... for example: "if your sound card is realtek then you need to go to realtek.com to download drivers".
akuma_ryu21
dont forget to rate!
Jan 30, 2011 | Computers & Internet
Hi .i have hp compaq 610 laptop.my in build speakers not working.how can solve the problem.please help me.
The inbuilt speakers on my laptop do not work. I believe the headphone input socket to be the problem because when i stick my headphones in it only works if i squeeze the laptop near the socket. The input has been quite heavily used so i'm quite certain its broken somehow. Anyway, my layman theorising has led me to the conlcusion that my laptop thinks that headphones are plugged in when they're not and so disables the speaker so maybe if i could disable the headphone input the speakers might work. I'm sorry if this sounds confusing but my computer knowledge is really, really limited. Any help would be massively appreciated. thanks
Jan 02, 2011 | HP Compaq Computer Speakers
Bose companion 2 laptop speakers quit working
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow? right click re-install drivers
hope this helps good luck
Aug 30, 2010 | Bose Companion 2 Computer Speakers
No sound
Try taking the computer back in time.
Start > Help and Support > Undo changes to your computer with System Restore > Restore my computer to an earlier time > select a date prior to when the sound quit working
Mar 14, 2009 | Toshiba Satellite P105-S6197 Laptop
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
LAPTOP SOUND DISFUNCTIONS.
hi
try to go to control pannel of the computer then go to sound and then check the setting their as it required ,if it doesnot work then go to run and then type in devmgmt.msc and it will open up devicemanager and then go to sound and check that it doesnot have red ex if it has a ed ex then right click on to it and try to enable it and it will definetly work
Nov 29, 2008 | Computers & Internet
Sound dont work on my computer
GO TO CONTROL PANEL AND LOCATE SOUND SPEECH AND AUDIO DEVICE CLICK ON IT WHEN IT OPEN A TASK BAR CHECK IF THE MUTE TASK IS NOT MARK IF IS MARKED THEN UNMARK IT AND TRY TO PLAY MUSIC TO SEE IF IT WORK IF IT DOES NOT WORK THEN YOU WILL NEED TO REINSTALL THE SOUND CARD DRIVER.
Nov 19, 2008 | HP Pavilion dv6000z Notebook
Firewave not recognized
The solution I found which seems to work is to go into Activity Monitor, and quit "coreaudiod". This forces it to restart and rescan for audio stuffs which makes it work.
Mar 29, 2008 | Griffin Technology FireWave Surround Sound...
XBOX LIVE DOWN?
Well I have been having trouble gaming all week long! Especially with Halo and Call of Duty 4. It seemed to be a little better today but they are definatly having problems!
Jan 11, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
