Question about Maytag Bravos MTW6600T Top Load Washer
Does not spin and makes a cranking noise - Maytag Bravos MTW6600T Top Load Washer
    New Friend:
    Problem Solver:
  • 6 Answers
This may be a motor coulping problem. I replaced mine today on a Kenmore it took 30 minutes time and a $25. part picked up locally. Was able to get a good diagram on line to take the housing off the machine and move the necessary parts to get to the coulping. Smile, clean clothes are not far away!
Posted on Jan 15, 2013
1998 C200 elegance auto, will not crank the engine over just makes clunk.
Could be a defective battery, bad solenoid, or even bad ignition switch. When I was fixing cars, I always replaced the solenoid when I replaced the starter, but your mechanic might not have.
Aug 31, 2016 | Mercedes-Benz C-Class Cars & Trucks
When trying to start my car its making a whinning noise and wont crank what could it be?
If the starter is spinning and not engaging the flywheel to start the car, suspect a defective starter drive clutch and starter replacement will be required
Mar 03, 2016 | Cars & Trucks
I put a alternator on now it wont crank, jus spin over
Ok , what type of toyota and type of engine, year too would help.
When you say it spins over is the starter motor making noise but the motor does not turn? Cranking and spin over are the same terms of words. Cheers
Jan 07, 2014 | Toyota Cars & Trucks
Refuse to start, who much will it cost me to buy another one?
another what?
NO CRANK or NO START
no car starts unless cranked fast. or pushstarted (stick) or jumper cable cranked.)
if it dont crank
1: check all fuses.
2: try jumper cable start, does it crank now (stater makes noise and engine crank shaft spins(eyes see that)
Aug 05, 2013 | Honda CR-V Cars & Trucks
Plymouth acclaim, the power steering went out a week or so started making a noise wen turning or taking off, I noticed the belt had a crack in it, tried to make it home & the belt just shredded apart,...
well as for the tear on the belt the power stering pump is proably not so good enymore if the pully spin with the belt then it no good and when your put the belt back make sure you got it on right if you crank it and the power steering pulley isint moving then your just gonna shred another belt after another
Jan 18, 2013 | Cars & Trucks
My car keeps making a chirping noise when I start the car up sound like the belt but the belt is tight, what could it be?
take belts of there are sevrall pulleys on there spin one at time check for play on each one of them if any noise out of ethere one of them replace it if your not able to turn one of them thats the bad pulley ok check all pulley on it even alternator and power stering one not the crank one ok the crank one is way at buttom dont try that one that one you wont be able to turn let me know
Nov 12, 2012 | 1999 Ford Taurus
1992 chevy 1500 spinning motor , not cranking. New coil..under cap looks clean..no scarring from arching..spark off plugs..gas coming in..if battery is low enuff to turn motor would that also keep it from...
If you mean just a spinning noise you'll need a new starter but clean the battery connections first with a steel brush. poor or loose connection cause the intermittent problem with click,click crank.
Jan 02, 2011 | 1992 Chevrolet K1500
Will not spin. makes ticking/clicking sound but no spinning.
For washer that's not spinning but making a clicking noise, then your washer could have a broken coupling. I believe that with Frigidaire, they're calling it as "Gear-crank"
Please check the link below so that you could see what a gear-crank is:
http://www.repairclinic.com/Frigidaire-Washer-Dryer-Combo-Parts?n=49
You need to contact a repair tech to check the coupling of you washer. If it's the one on the picture, then it would only costs you $5 for the coupling.
Have a great day!
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
1983 Ford F150
the way I understand this question, is that you were driving when the engine locked up. In that case, I would say that you have blown the engine, and you are hearing your starter spin on the flywheel because the engine will not crank over.
Sep 29, 2008 | 1983 Ford F150
Maytag Bravos MTW6600T Top Load Washer Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
