Question about Nintendo DS Lite Console
Touchscreen not working
When power up the Nintendo, it use to say touch screen to continue (on the touch screen) It no longer says and it is not responding to stylus touch. Went to settings, using key pad and tried to calibrate and it freezes up. Any thoughts?
    Problem Solver:
  • 8 Answers
Umm.. i didnt see the video, but go on www.youtube.com and just search "how to fix touch screen". there should be videos that tell u how to fix it. i didnt see the video since my DS didnt have that problem..HOPE THIS HELPS!!!!!!!!!!!
Posted on Jan 25, 2009
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
My DS's touchscreen won't work i can use the arrows to navigATE but not my touch scren.
There are a few third party screen replacement options available for you if your DS is no longer covered by the warranty.
A replacement touchscreen is about 30-$50. They are not to hard to replace if you have the right tools.
Look around for "DS replacement touchscreen" & "DS Specialty screwdriver" They can be found on Ebay and in shops on google.
Let me know if you have any further questions.
Nov 21, 2009 | Nintendo DS Console
Nuvi touchscreen dead
settings.
1. Turn the device OFF.
2. Place your fingertip or the eraser end of a pencil in the top right corner of the touchscreen.
3. Apply pressure in the top right corner of the screen.
4. While pressing down on the screen, power ON the unit and continue pressing on the screen. A message displays
to confirm if you really want to delete all user data?
5. Touch Yes.
6. The unit will now restart.
7. Follow the onscreen prompts to set up the nuvi.
Jul 31, 2009 | Garmin Nuvi 350 Car GPS Receiver
Ds lite dropped while open, touchscreen now white.
With white screens it usually the LCD that went out, since D.S. do not have a reset button, the only way to reset it to Factory settings would be to remove that battery, and you would need to remove the little screws on the back. I would leave that last. However if you guys have had this DS for less than a year i would contact Nintendo, or go to the website
because you would still be under the one year Manufactures warranty. I would highly recommend to not state it was dropped. Just that the screen went blank all of a sudden. Touch screen works fine. Make sure there is no physical damage though, as that usually voids warranty. I had to do that for my Wii. No cost to me since under one year. If its been longer then the year then you could do the hard reset by removing the batter for a few mins.
Good Luck!
Jun 15, 2009 | Nintendo DS Lite Console
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Nintendo ds lite
First try to recalibrate the screen (start up the DS, and do the following--text from nintendo.com):
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • Ifthe touch screen is not responding properly, hold the Nintendo DS at anangle so that you can see where the edges of the Touch Screen meet thehousing of the system. Look around the entire edge of the Touch Screenfor any foreign material (such as crumbs, etc.) that may be wedged inbetween the Touch Screen and the housing of the DS. Foreign material inthis area can cause the Touch Screen to work incorrectly.
If the screen still does not work, you need to buy a new touchscreen. Many vendors sell these, here's an example:
http://store.richspsxparts.com/nidslito.html
You will need a good tri-wing screwdriver to do this repair (don't buy a cheap knockoff--they will strip your screws). Try one like this: http://www.play-asia.com/paOS-13-71-1e-49-en-15-tri_wing-70-1fe.html
Then follow the step by step tutorial at:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Dec 07, 2008 | Nintendo DS Lite Console
Nintendo DS touchscreen problem
try calibrating the touchscreen....
Jan 08, 2008 | Nintendo DS Console
TOUCH SREEN NINTENDO DS LITE
aparently fitting a new touchscreen works, i have just ordered one from ebay, cost me a tenner
Dec 31, 2007 | Nintendo DS Lite Console
Nintendo DS Lite
Are the batteries fully charged? when the first screen comes on when you first use the power switch and it says at the bottom to touch the screen. Just push the A button. If your DS still shuts off only when you touch the touch screen let us know.
Sep 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
161 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
