Question about Home
Where can i purchase an on/off switch for my aqua glass whirlpool tub
  • 717 Answers
We have all the old Aquaglass switches or the replacement for the ones that are not made anymore. Aquaglass Parts
Contact us at: sales@uspartscenter.com or Toll Free 888-521-6183
Rod
US Parts Center
Posted on Feb 07, 2013
  • 100 Answers
SOURCE: whirlpool tub pump only runs in slow speed
give aquaglass a call at 731-632-0911 they will be glad to help you,i worked for them at one time
Posted on Feb 14, 2010
  • 374 Answers
SOURCE: bath tub installation
Okay lets start with the most obvious: Check all studs to ensure they are plumb. I am assuming all sheetrock and tile has been removed. if so measure the distances from the bottom plates on the end walls. it should be 60 inches in the clear. measure the height of the tub from the edge of the skirt that contact the floor to the top of the skirt then measure this distance off on the front and rear studs on both end walls and mark it off. Now measure to see that you still have 60 inches in the clear at both the front and rear locations. Now measure the tub as well to ensure it wasn't mis-manufactured. If all your measurements come in at 60 inches you should be able to bring the tub in and slide it in as it is when it is finished. If you find out that you have less than 60 inches in the clear for the tub you can use a drill and jigsaw to remove additional wood from the studs to get it to drop in. Once in you can fir the wall back out to the original dimension and sheetrock and tile. One thing you need to remember is that you may need to take wood out of bot ends to get the drain to rough in correctly.
I hope this helps you out and thanks for using Fix Ya.
Posted on Oct 16, 2008
  • 123 Answers
SOURCE: aqua glass whirlpool tub leaks. looking for
To my knowledge there are no closure caps for your tub; you can however purchase new jets with new seals if the tub is leaking through the jets.
Posted on Sep 01, 2009
  • 100 Answers
SOURCE: CAN THE JETS BE CHANGED OUT ON THE AQUA GLASS TUB,
aquaglass customer service will help you 731-632-0911
Posted on Feb 15, 2010
  • 12744 Answers
SOURCE: I bought a house with aqua glass whirlpool tub (14
will have to remove access panel or make one the motor /pump assembly is mounted to the tub test for power to the switch and pump the numbers u are looking for are their by pump
Posted on May 04, 2010
Aqua glass jetted tub. How do I get the on/off switch to turn off jets?
it is a air switch, it has a tube running from the button to a box mounted on the pump motor,it could the hose has came off
Oct 08, 2015 | Home
Hot Tub won't Turn On.
First check the breaker box for the house and see if it has power.
Jun 26, 2015 | Home
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
I have an Aqua Glass whirlpool tub, and the jets no longer work. When I hit the on/off button, it just makes a clicking sound. Do I need a new pump? If so, what type do I buy?
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
888-521-6183
US Parts Center
Nov 30, 2013 | Home
I have an Aqua Glass Whirlpool Tub. The jets shut down and when I push the on/off button, it just makes a clicking sound. Do I need a new pump? If so, what kind do I order?
You could easily have the whirlpool fed by a double breaker. Try turning it off and back on and see if all is back to normal
Nov 30, 2013 | Home
I have an Aqua Glass Jaccuzzi that I haven't used in 10 years. The last time it was used it worked perfectly. Now I can't turn it on at all. I don't remember is just the round dial that
Check the circuit breaker and make sure you have power to the pump.
If you have power to the pump and it is not operational when the tub is full of water and you are in it then I would say you have a serious problem.
Most all of the older control that Aquaglass has used in the past have been discontinued.
You may want to visit this link and identify your control before you begin t trouble shoot your system.
Rod
US Parts Center
888-521-6183
Feb 27, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
I have an older aqua glass tub that has a controller made by tridelta Industries inc. they are no longer in business and I cant find the controller # CA 3585
That control and the pump are no longer made. That system is very old.
What brand of pump do you have? If you can get me that information I will be able to find a solution for you.
Rod
www.uspartscenter.com
Jan 22, 2013 | Whirlpool Home
I bought a house with aqua glass whirlpool tub (14 yrs old). Motor won't come on and I can't find reset button or serial number. Where are these items?
May 03, 2010 | Kohler 1209-LA-0 Hourglass Whirlpool with...
Whirlpool tub pump only runs in slow speed
Feb 14, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Aqua glass whirlpool tub leaks. looking for closure caps to close off the jets for good.
Aug 29, 2009 | Home
Home Logo
702 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
