Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Can not get new V-belt installed.
Is there a special trick or tool used to install a new v-belt on a craftsman 18.5 hp 42 in. deck.
  • 3,037 Answers
Hi donrlynn
What happened to the old belt, did it get old and you just wanted to put a new one on or did it break while operating? If it broke during operation then it is possible that you have a pulley that is off of alignment and needs to be fixed first otherwise the belts will keep breaking. If that isn't the case then you should find one pulley that is the tensioner pulley on the bottom. This is easier if you have more help. You need to wind the belt as the diagram shows through every pulley except for the biggest one. Then you need to compress the tensioner pulley as much as you can and then gradually ease the belt around the biggest pulley. You can use a flat screwdriver or other similar tool to pry it over the lip of the pulley. Be careful, don't hurt yourself and let me know if you have anything further to ask about this.
Thank you for using Fixya and good luck
bestdarngood
Posted on Jan 25, 2009
  • 98 Answers
On the Front of the Deck where the Deck Hooks to the Front of the Mower Frame are 2 Adjusters. These Adjustments will Shift the Deck to the Rear and Tighten the Belt.
How do you put a drive belt on a craftsman 14.5 OHV IC Gold 42 in. Model # 917.270514
Hi Anonymous, the link below is a youtube video showing how to install a 42" deck belt on a craftsman...... CHEERS..
https://www.youtube.com/watch?v=W1ekBwmBT1c
EASY CRAFTSMAN DECK BELT INSTALLATION
Apr 15, 2016 | Craftsman Garden
How do you replace the blades on a 42 in. deck? do they need to be placed in a special way?
use the blades for leverage when loosening the bolts. when putting new blades on, hold the blade in the star center hub install washer and bolt. use blade for leverage when tightening.
Jun 23, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
New drive belt immediately burned up after replacement
Make sure blades move ok. Check bad spindle bearings too
Oct 22, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
19.5 hp 42 " automatic craftsman . The trans seems to be slipping,does not want to go up any incline. I have purged it and installed a new drive belt. did not help.
recheck ur drive belt either wrong belt or spring/idler/tentioner pulley needs attention adjustment replacement also check free wheel actuator that not partially activated
Jun 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I need to replace a belt on a craftsman with a 42" deck.What size belt should I get.What length.
Craftsman is made by Murray Corp. who also makes Murry, YardMan, Lowes, Penncraft, and on and on. Go to your local Wal-Mart, Lawn and Garden Dept. and look for the belt that fits the Murray, YardMan, Lowes, Toro, 42" Deck 14-18 HP. Or take your old belt with you, and stretch them both end to end holding the end loops with each hand. Or you could go to Sears and just tell the parts department what your mower is and they can get you a Craftsman belt. It will be the same one you get at Lowe's, Wal-Mart, ect, probably just cost a little more. Sears doesn't make mowers, they just have their colors and names put on by the manufactorer. And Murray of Ohio is the maker of these.
Sep 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I change out the primary belt on a Craftsman 17.5 hp 42" mower? The new belt is around the pulleys but it is very loose.
This belt is easist to install with the deck all the way down. Make sure there are no burrs on any of the pulleys, (will eat up your new belt in short order), also make sure that the 2 drive pulleys for the blades turn freely, (may have grass impacted around them, you may need to remove the 2 guards on top of the deck to clean, (if they do not spin eaisly). Triple check to make sure the belt is properly routed, one mistake and your belt is broken as soon as you engage. With the engine OFF, engage blades to check tension. If the belt is still loose, you likely have it routed incorrectly.
Jun 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
May 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
21 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
