Question about Lowrance M68C GPS Receiver
Lowrance m68c not powering up and cloudy screen
The unit is powered by a 12 v sealed battery. The unit will power up for a couple of seconds then shut off. While on the screen has a large area that is darkly cloudy. I rotate 2 batteries and they both are charged. The company said it won't repair the unit simply because it is older than 5 years old. I think the unit is 6 years old.
SOURCE: powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Posted on Jan 10, 2008
hydetech
  • 113 Answers
SOURCE: Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Posted on Mar 17, 2008
SOURCE: Lowrance LCX-16ci - screen's gone out
I have a working unit with a bad antenna. Interested?
Davidwcantrell@comcast.net
Posted on Aug 07, 2008
SOURCE: i have a lowrance lms332c
try to hold in the page button and power button at the same time to reboot your unit, But you may or may not lose waypoints,
Posted on Aug 12, 2008
SOURCE: Power to Lowrance GPS
Yes you have to hook up the red wires together to the + and both black ones to the negative, otherwise the antenna won't be supply in current , and don't forget to insert behind the red wire a fuse and a switch to avoid to discharge your battery .
Bernard.
Posted on Apr 26, 2009
Lowrance hds-5 will not power up. lowrance will not work on if out of warranty. does anyone?
most the time its a bad key pad when unit wont power on and what it cost to repair you can buy another one check the pins in the power cord see if there not broke or bent yes they break take a 12 volt test light see if you have power going to power in the plug that connects to back of unit if you have power . . .bad key pad
Feb 25, 2013 | Lowrance HDS 5 Fishfinder GPS Chart...
ENDURA POWER BUTTON BROKEN
Sounds like the power button is pulled loose from the circuit board or the power switch went bad for some reason. You can't check this out as it is sealed to be waterproof and opening it violates the warranty. The only way to address this would be to send in to Lowrance Customer Service.
This should not be a common problem and should be covered by manufacturers warranty if still within the 1 yr warranty period. If out of warranty, Lowrance Customer Service should still be able to replace or repair it for some sort of cost.
To speak with US based Lowrance Customer Service, call toll-free at 1-800-324-1356, Monday through Friday from 8:30 am to 4:45 pm Central. Or email them at products@lowrance.com with problem, product model and serial number (located between the batteries in the battery compartment). CS On Hold times range between 0 and 4 minutes right now with Monday mornings being their busiest times.
A Lowrance Guy
Jan 30, 2012 | Lowrance Endura Out&Back Handheld GPS...
The plug in to the M68 is crumbling away. now will not power up.
Mine is having the same issue. I wrapped it with electrical tap around the outside to hold the pins inplace temporarily. Anyone know if you can buy just the plug or do you have to buy a whole new transducer?
Oct 10, 2010 | Lowrance M68C SMAP w Single Frequency...
My Transducer had broke and the sonar went out, then the transducer fell completely off and the unit itself will not power up. I checked the power ot the unit and i have 12 volts going to the unit. It...
All Lowrance systems have an in-line 3 Amp fuze. My guess is that when it broke and fell off the fuze shorted out. Look back the power sypply to the unit and you will find the in-line fuze. Replsacit with a new 3 Amp fuze and you should be up and running.
Aug 30, 2010 | Lowrance LMS-332C GPS Receiver
332 powering problems
Power switch is stuck on. I had the same problem. the only repair was to disable the powerswitch internally and install one on the side (waterproof).
May 24, 2010 | Lowrance LMS-332C GPS Receiver
How i can reset an a lowrance endura sierra?
Hello there:
here is what you can try to do is first unplug any power going to the unit and remove the battery these units have a internal reset device that will reset it'self after a given amount of time which is about 1 hour.
during this time press in on the power button for 2 minutes and if it has a reset button it press in on this for 2 min leave the battery and the power out of the unit for the rest of the remaining time i had mentioned.
now plug in the power cord back in it and start the unit now if it works ok simply turn off and replace the battery and you are now done ok
Hope this is very helpful for you
Best regards Michael
Dec 22, 2009 | Lowrance Endura Sierra Handheld GPS...
Powerin up - screen goes blank after a few swconds -
Nov 15, 2006 | Lowrance LCX-19C GPS Receiver
Lowrance M68C GPS Receiver Logo
74 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
